GM Strut Brace and the Hood: Rubbing Issues
  • #76
    I just glued some pieces of rubber to the hood. It's worked so far.
    • #77
      Anyone took a grinder to the bottom of the mounting flanges on the STB? Not sure how thick the plate is, but it would make it sit lower on the towers.
      2007 Pontiac G6 GTP - 3.6L DOHC VVT
      Stock DD
      1998 Camaro Z28 - 6.0L 408cid LQ9
      T76 Turbo
      FMIC
      New Transmission is in
      • #78
        I'm not sure I would want to do that, easier just to put some sort of pad there.
        • #79
          Got mine in today and it went straight on. I didn't even take it into the garage, I popped the hood and bolted her up. And took it around the block. I will hunt for something to stop the rubbing.
          Originally posted by Nikki
          You are an e-pimp.
          Originally posted by beitodesstrafe
          I tried too, my penis way too big
          07 GTP Coupe, Black, GT-R Exhaust #1, Dr speed Cold air box, GM STB, White Face Gauges, Intigrated Ipod, Altezza tails, Painted headlights with black reflectors and no amber turn signal cover and Nokya Ultrawhite bulbs all around, VMS ECM Tune Beotches, With the TCM tune soon to come.
          My youtube. http://youtube.com/user/joebro82
          The old hooptyhttp://www.cardomain.com/ride/2412743
          • #80
            Re: GM Strut Brace and the Hood: Rubbing Issues
            I will go with the washer mod
            Not only eliminate the rubbing, it allows air to enter the engine bay to aid cooling if you remove the rear seal
            • #81
              I put mine between two trees and bent it. You cant even tell and there is enough play
              in the bolt holes to accomodate widening it which lowers the bar.
              Anyway...there is still play left. I may do it a bit more.
              • #82
                Ya I noticed I'm having SERIOUSE rubbing issues with it and the MPD hood. I'm gonna take it out and bend it. I looked the other day and the padding I put on to stop it with the stock hood were almost starting to rip cause it's so bad.
                2005 CGM GTO.
                • #83
                  It bends easy so be careful. That has worked for me though on the MPD.
                  • #84
                    It sounds like your hood wasn't lined up right. I just put velcro(fuzzy side) at the contact points and all is cool.
                    2008 Mazda Mazdaspeed3 GT
                    Forge Motorsports BPV
                    CP-E Xcel Nano SRI
                    HKS 3" Hi-Power CBE
                    HyperTech Max Energy Tune
                    • #85
                      could you raise the hood an inch or so?
