Type: four speed front-wheel-drive, electronically
controlled, automatic overdrive transaxle
with electronically controlled torque
converter clutch.
Maximum engine torque: 280 lb-ft (380 Nm)
Maximum gearbox torque: 400 lb-ft (542 Nm)
Gear ratios: First: 2.92 Second: 1.56 Third: 1 Fourth: 0.7 Reverse: 2.38
Maximum validated gross vehicle weight: 2903 kg (6400 lb)
Case material: die cast aluminum
Shift pattern: (2) two-way on/off solenoids
Torque converter clutch: pulse width modulated solenoid control
Converter size: 245mm and 258mm (reference) (diameter of
torque converter turbine)
Weight: 93 kg (205 lb) (M15) (wet)
96.6 kg (212 lb) (MN3) (wet)
97.2 kg (214 lb) (MN7) (wet)
112.5 kg (248 lb) (M76 with power take off
(PTO) Unit) (wet)
Fluid Type: DEXRON IV
Fluid capacity (approximate): bottom pan removal: 7L (7.4 qt)
