Type: four speed front-wheel-drive, electronically
controlled, automatic overdrive transaxle
with electronically controlled torque converter
clutch
Engine range: 3.0L - 3.4L
Maximum engine torque: 205 lb-ft (278 Nm)
Maximum gearbox torque: 325 lb-ft (440 Nm)
Gear ratios: First: 2.95 Second: 1.62 Third: 1.00 Fourth: 0.68 Reverse: 2.14
Maximum shift speed: 5800 rpm
Maximum validated gross vehicle weight: 1990 kg (4347 lb)
Case material: die cast aluminum
Shift pattern: (2) two-way on/off solenoids
Shift quality: variable bleed solenoid
Torque converter clutch: pulse width modulated solenoid control
Converter size: 245mm (reference) (diameter of torque
converter turbine)
Fluid type: DEXRON VI
Dry: 74.7 kg (164 lb)
Wet: 85.1 kg (187.6 lb)
Fluid capacity (approximate): bottom pan removal: 7L (7.4 qt)
Complete overhaul: 10L (10.6 qt)
dry: 12.5L (13.2 qt)
Transfer design: two-axis design, link chain assembly
