Originally posted by coqui_inaG6
Foglight Switch LED Indicator Flashing or Completely Out
Originally posted by bristol16
actually the bulbs and the switch should be on 2 separate circuits. the switch should trip a relay which should feed power to the bulbs directly off a strong power source. i doubt the switch carries enough power to run both bulbs.
I have my fogs set up as my DRLs (thanks to Bristol's help). Unless I press the button, the LED in the switch does not come on, even though my fogs are on. I set the power up to run through the foglight relay under the hood. If the power from the lights triggered the LED, the LED would always be on in my car.
Originally posted by jnakThis is correct. There is a relay under the hood that turns the fogs on/off. Power going to this relay is independent of the power running the LED in the switch....
The momentary push button fog lamp switch is an input signal to the BCM. The BCM has a single "high side" drive output which provides an output voltage which is used both to energize the relay as well as power the LED in the switch. This comes out 2 different pins on the BCM so they migh look to be independently powered but really from same place.
The relay contacts of course handle the bulb load.
mine started flickering today like it was at a disco that I didnt know about... oh well, I'll get that fixed along with the second new rack, steering wheel centered and extended crank fixed (again)Originally posted by ToyzOriginally posted by simplyredwhat do you guys think about switching up the teams again?!
my fog light also started flickering the other day...i turn the fogs on, the light stays on, then flickers, then goes out. just thought id let people know that it's still happening...You're doing it all wrong...you gotta cup the balls, relax the jaw...
I was going to the store 2 days ago and I was looking at the reflection of my car in his rear end when I noticed my fogs weren't on (I could've swore I just turned them on!). Sometimes I feel like I don't push the button all the way and have to risk crashing to look underneath my steering wheel to see the dang light. Anyhow, along my way I noticed the light flickering! I'll be taking it in sometime this week to get it fixed. Thanks for the help everyone"When you find that you've dug yourself a hole, STOP DIGGING!" -Unknown Car Salesman
Mine started doing it today.
In addition, I've also noticed some weird behaviour with my reprogrammed BCM with the dash panel lighting on.
It was cloudy today, automatic headlamp was kicking in and out. I generally have my dash set to a lower intensity, but the BCM keeps it at full. So when it's auto, it's my setting, manual it's full. I turned on the parking lamps, and it was full. It got a little darker, auto lamps kicked in, dimmed my dash. So I flicked it back to auto, but then afterwards it got a little brighter, headlamps went out. But instead of going back to off, the dash went to full intensity. Tried turning parking lamps on then off, dash still stays on at full intensity.
This is the first time it happened ever since the reprogramming.
Re: Foglight Switch LED Indicator Flashing or Completely Out
so once again im not the only one who has a all too common 6 problem--woohoo!! mine started doing this months ago... i just figured it was a fuse that was supplying power to the switch or sumtin... hasnt really bothered me much that its not lit..but maybe if the mod is easy ill just switch out the led to red
ok after reading through this i decided to go out and see wut i can do, well i pulled the switch out of the car and i pulled the switch apart
looks like i will be able to replace the LED. two solder joints. so im going to be running over to radio shack here soon and see if i can get a LED for it, im thinking maybe a red one.
Originally posted by ahuhnso i just realized there a drawer in my room that has nothing in it but tequila, condoms and a blow up doll. cant figure out if thats a good thing or not
