2006 g6 ecm question
  • 2006 g6 ecm question
    Ok I’ve done a little search. Unfortunately I’ve only got the phone to search with. Here’s what I got. I have po443 code. I have found that I’m not getting the ground from the ecm to the evap in the back by the tank. I have power but no ground. I have found the wire out of ecm and don’t have ground out of it. So what’s my next step to try and solve my problem. Thanks
    Re: 2006 g6 ecm question
    I guess I’m wondering if there is something else I can test. what are your thoughts on if the ecm is faulty or is there something else causing single lost to the evap solenoid by the tank. Like I mentioned above, I have positive volts to the plug but not a ground which the way I understand the ecm sends a ground to the solenoid which opens the vent. Thanks
