Help
  • Help
    I have a 2010 G6 with alittle over 111,000 miles, the problem it the car will not crank. Have checked the fuel pump, coil packs, spark plugs, motor is getting fuel. Does anyone have any ideas what it could be? There is no codes when read by computer.
    Re: Help
    When you say it does not crank. Do you mean you turn the key to start it and nothing happens? Do you hear any clicks from the engine bay while trying to start?
    Start simple. Make sure the battery is good and that all the battery connections are tight and clean.
    Check the ground cables where they attach to the body and the engine. And check the positive cable at the starter itself.
