Results 1 to 12 of 12
Thread: Need wiring diagram for 2007 Monsoon amp
  1. #1
    suckit
    G6 Newbie
    Join Date
    Apr 2016
    Location
    Wisconsin
    Posts
    9
    Name
    Dan
    Year
    2007
    Make
    Pontiac
    Model
    G6
    Trim
    GT
    Engine
    3.5Lvvt V6 LZ4
    Transmission
    4 Speed Auto
    Style
    Coupe
    Color
    Ivory White
    I haven't been able to find a diagram to match my amp. I've found This one, but it doesn't match.
    If it matters, the amp is in a 2007 GT. It looks like this;
  2. #2
    suckit
    G6 Newbie
    Join Date
    Jun 2016
    Posts
    8
    Year
    1964
    Make
    Pontiac
    Model
    G6
    Trim
    Base
    Engine
    2.0L I4 S/C LSJ
    Transmission
    4 Speed Auto
    Style
    Coupe
    Color
    Liquid Silver Metallic
    Re: Need wiring diagram for 2007 Monsoon amp
    just installed subs in my 09 g6 with monsoon. I used a line out converter and I only needed to use 4 wires to splice into the converter. what I used was:
    Left rear + is brown
    left rear - is yellow
    right rear + is dark blue
    right rear - is light blue
    there is 2 different brown and yellows but I believe I used the back 2 that are next to each other. the converter hooks right into the rear speakers and then you just plug your RCAs into the converter
  3. #3
    suckit
    G6 Newbie
    Join Date
    Jun 2016
    Posts
    8
    Year
    1964
    Make
    Pontiac
    Model
    G6
    Trim
    Base
    Engine
    2.0L I4 S/C LSJ
    Transmission
    4 Speed Auto
    Style
    Coupe
    Color
  4. #4
    suckit
    G6 Newbie
    Join Date
    Jun 2016
    Posts
    8
    Year
    1964
    Make
    Pontiac
    Model
    G6
    Trim
    Base
    Engine
    2.0L I4 S/C LSJ
    Transmission
    4 Speed Auto
    Style
    Coupe
    Color
    also, use the middle clip and the thin pink wire for remote turn on
  5. #5
    suckit
    G6 Newbie
    Join Date
    Apr 2016
    Location
    Wisconsin
    Posts
    9
    Name
    Dan
    Year
    2007
    Make
    Pontiac
    Model
    G6
    Trim
    GT
    Engine
    3.5Lvvt V6 LZ4
    Transmission
    4 Speed Auto
    Style
    Coupe
    Color
    Ivory White
    I'm trying to tap into the inputs for the amp, before the signal gets molested by it. Preferably the front. I also need the specific output channels because I'm going to put bass blockers in right back there after the amp. I know, trying to do everything the hard way....
    After a little trimming this ended up working quite well.
  6. #6
    suckit
    G6 Newbie
    Join Date
    Apr 2016
    Location
    Wisconsin
    Posts
    9
    Name
    Dan
    Year
    2007
    Make
    Pontiac
    Model
    G6
    Trim
    GT
    Engine
    3.5Lvvt V6 LZ4
    Transmission
    4 Speed Auto
    Style
    Coupe
    Color
    Ivory White
    Nobody?
  7. #7
    suckit
    Established G6er
    CruisinG6's Avatar
    Join Date
    Nov 2009
    Posts
    1,731
    Year
    2009
    Make
    Pontiac
    Model
    G6
    Trim
    Base
    Engine
    2.4L I4 LE5
    Transmission
    4 Speed Auto
    Style
    Sedan
    Color
    Carbon Black Metallic
    I will take a look when I get home at the wiring diagrams I have and will get back to you
  8. #8
    suckit
    G6 Newbie
    Join Date
    Apr 2016
    Location
    Wisconsin
    Posts
    9
    Name
    Dan
    Year
    2007
    Make
    Pontiac
    Model
    G6
    Trim
    GT
    Engine
    3.5Lvvt V6 LZ4
    Transmission
    4 Speed Auto
    Style
    Coupe
    Color
    Ivory White
    Thank you so much!
  9. #9
    suckit
    Established G6er
    CruisinG6's Avatar
    Join Date
    Nov 2009
    Posts
    1,731
    Year
    2009
    Make
    Pontiac
    Model
    G6
    Trim
    Base
    Engine
    2.4L I4 LE5
    Transmission
    4 Speed Auto
    Style
    Sedan
    Color
    Here's a couple.
    First one is the Radio wiring diagram including wiring to the amp
    Second one is the wiring from the amp to the speakers
    I have color coded ones from another program as well, but these seem more accurate.
    Let me know if they work for ya!
  10. #10
    suckit
    G6 Newbie
    Join Date
    Apr 2016
    Location
    Wisconsin
    Posts
    9
    Name
    Dan
    Year
    2007
    Make
    Pontiac
    Model
    G6
    Trim
    GT
    Engine
    3.5Lvvt V6 LZ4
    Transmission
    4 Speed Auto
    Style
    Coupe
    Color
    Ivory White
    Thank you so much!
    It may be asking too much here, but do any of those numbers refer to the pin-out of the plugs? The use of multiple wire the same color is a bit of a hurdle. Not one I can't overcome though.
  11. #11
    suckit
    Established G6er
    CruisinG6's Avatar
    Join Date
    Nov 2009
    Posts
    1,731
    Year
    2009
    Make
    Pontiac
    Model
    G6
    Trim
    Base
    Engine
    2.4L I4 LE5
    Transmission
    4 Speed Auto
    Style
    Sedan
    Color
    Yes, C1, C2 for connector one, connector two etc etc.
    And each wire number is the location on the connector where it connects.
    I would verify each wire if possible before doing any work on the wires. I have run into incorrect wiring diagrams quite often.
    It looks like each pair of wire is either twisted together or wrapped in their own shielding.
  12. #12
    suckit
    G6 Newbie
    Join Date
    Jun 2019
    Posts
    1
    Year
    1964
    Make
    Pontiac
    Model
    G6
    Trim
    Base
    Engine
    2.0L I4 S/C LSJ
    Transmission
    4 Speed Auto
    Style
    Coupe
    Color
    i just bought a 2006 g6 gtp with a monsoon amp. i want to add another amp and subwoofers in the trunk. i would like to tap into the input wires to the monsoon amp in the trunk, but im not having any luck finding the wiring diagram. the pics in this thread are not coming up on my computer. any good pics out there to look at?
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
