Re: Wheel Spacers 08 G6 GXP?
Old studs punch out pretty easily. New studs can be a pain. It's not too bad if you can punch them in most of the way and then use a large socket or bunch of washers and a sarraficial lug to pull the stud all the way out. I did my first set with the wheel bearings attached and it's doable. If you think you might need wheel bearings soon tho, you should just put the studs on a new bearing.
