After changing the gasket about ... a 3 weeks to a month ago, I just HAVE to show you guys how it looked when I took it out.
Oil Filter Adapter Gasket
Re: Oil Filter Adapter Gasket
Do you have to lift the motor when replacing the oil pan gasket on the 3.5?
Show: GXP Hood - 2009.5 Front Bumper & Rear Spoiler - Black Housing Headlights - White LED Reverse and License Plate Lights- White LED Interior Dome & Map Lights - Matsushita Gen4 6000K HID Lows - White LED Fogs - GXP Rear Bumper - White LED KPH Instrument Cluster Conversion - 15% Tint
Go: CRAB + FPU Powder coated wrinkle black - Racingline STB , MMI & Grounding Kit - Dash Hawk - Front 4 Piston Brembo Brakes - Rear Cobalt SS TC Brakes - BMD Stainless Steel Braided Brake Lines & Endlinks - WAMS 93 Tune - Custom Magnaflow Exhaust - Milzy Motorsports Headers
Progression Page: http://www.g6performance.com/forum/s...ad.php?t=22818
http://www.cardomain.com/ride/2594110
I think I'll have to lift my 3.6 up a little to do mine.
Just had my oil pan gasket replaced on my 3.5 they had to separate trans from motor because of some small tab cost around 600 to have this done got the vehicle back and its still dripping oil from somewhere any ideas on where to look? My mechanic says the pan gasket needed replaced,
Originally posted by FOURMOREMARINE View PostJust had my oil pan gasket replaced on my 3.5 they had to separate trans from motor because of some small tab cost around 600 to have this done got the vehicle back and its still dripping oil from somewhere any ideas on where to look? My mechanic says the pan gasket needed replaced,
You could look into that after all the other areas are checked.
