2010 Speedometer Swap HOW-TO
  • #76
    Re: 2010 Speedometer Swap HOW-TO
    Gtprix says it should. Just message him to confirm any new information on this mod
    • #77
      Has anyone done this swap on an 06 g6 gtp without flashing the bcm w/ success?
      Mods: Matte Black Plasti-Dip on Wheels, Upper Grille, GM/Trunk Emblems, Dupli-Color Red Calipers, Intake Res Delete, Crab Intake #3, Flush Mount Spoiler, AVS Rain Guards, Black Lower Recessed Grilles, Map/Dome Red LED's.
      Fixes: Sunroof Leak, Misc Interior Trim, Vanity Mirrors, Door Weather Stripping, Front Wheel Barrings, Control Arms, Lower Ball Joints, Tie Rod Ends.
      • #78
        We know it works in an 07. I thought someone did it to an 06 but I can't find proof.
        If you have the 3 spoke steering wheel and cruise control buttons to replace then at least it can all fit.
        I'm betting it will work but there's only one way to know for sure.
        • #79
          Any info. on the extra green wire I would need, what's kind of wire and adapter it's called, thanks!
          • #80
            Adapter? I just got the wire out of a junked g6 and popped the pin out of the factory plug. Lengthened the wire and put it in as I outlined.
            • #81
              A bump to this thread. I just found out about this day before and found all the parts I needed to install a new cluster. I've ordered everything (new cluster 20818950 and new cruise control steering wheel buttons D1952F) but was having trouble locating a new plug to use for spare terminal for new wiring. Looking at the picture I noticed it's a Delphi connector. Did research for an hour or two and figured out the part number for a new terminal outright.
              12089649-L Delphi Connection Systems Automotive Connectors FMALE 100 SERIES TIN CBL RANG 1.00-.80MM2
              Was really the only thing stopping me from doing this mod. I'm assuming that more people would have done this mod prior if they had known about this terminal. You can buy them in bulk or individual.
              Once all my parts have been delivered and get them installed, fingers crossed, I will come back and let everyone know if it was successful or not. No one has said straight up if it works in a '08 GXP. And if it does work I can look forward to installing an aftermarket radio without having to worry about losing the DIC.
              Happy modding folks.
              • #82
                That pin/wire seems to be a setback for many now, Unfortunately the ebay listings with these connectors don't seem to be active anymore.
                A trip to the junkyard could get the connector, then just remove the pin from it and wire accordingly.
                I may be stopping at one this weekend, I'll check to see if any are available.
                • #83
                  Negative. There are more than a few websites devoted to selling parts like this one. I just ordered it off of www.mouser.com. granted the terminal was only like 17 cents but shipping was something like 5 bucks. Not everything has to be on eBay.
                  • #84
                    I got mine from eBay. Bought a connector and sold off the pins to others doing swaps.
                    • #85
                      If you still need the wire for the cluster harness, I have 2 green ones.
                      • #86
                        Do you need the wire or just the pin, or both? I haven't done the full read yet cause I'm laging aha but if I need what you have I might take one if you have an extra
                        Progression Page
                        • #87
                          this is awesome. this would be my next project for my 06 g6.
                          • #88
                            Well, the wire connects to the pin. I don't think you can separate them when you take one off of a car. That's why you just splice a wire in.
                            • #89
                              Got my new gauge cluster installed! It was a success. Works in my '08 GXP. Only thing that doesn't work is the door chime, which im assuming would come back if I replace the stock radio and add an interface. Also, the TPMS isn't showing up. Its there but just shows blank dash line where the psi # should be. Im not too worried about that. I know how to use an old fashioned tire pressure gauge. Thanks for making this write up. Ill post again if something else arises.
                              • #90
                                Okay I lied. I guess from disconnecting the battery my TPMS came back up. So just the chimes dont work. Now I'm thoroughly ammused.
