2010 Speedometer Swap HOW-TO
    Re: 2010 Speedometer Swap HOW-TO
    Try tapping the info button while in manual mode and see if it comes up.
      Could the Speedo cluster with the DIC in the cluster have been lacking any special device to show the manual gear number on screen?
        Originally posted by 07gt View Post
        one thing i noticed today, when i put it in manual mode it dosnt show what gear im in on the dash anymore!
        oh well its the price to pay
        Press the INFO button until it shows the Temp and Odometer, then try shifting into manual mode and see if it shows up.
        Here's a section of the 2010 G6 owners manual:
        Originally posted by 2010 Pontiac G6 Owners Manual
        When in manual shift mode, the odometer will change
        from the vehicle’s mileage to the letter M, for manual
        mode, and a number indicating the requested gear
        range when moving the shift lever forward or rearward.
        If that doesn't work, then this may be one of those issues that can be fixed with a BCM flash to the 2010 spec.
          tried that, it just stays saying the outside temp and milage
            Bummer
              Noticed something odd lately.
              Ever since I got the new cluster it began showing my mileage as soon as I open the door, which isn't bad but it doesn't update.
              I noticed yesterday as I opened the door it said one number. But when I cycled through the menus and got to my odometer it was a whole 93 miles ahead.
              So I removed the key and opened the door and boom it updated and showed the current mileage.
              I normally leave mine on fuel economy so I never noticed this before.
              Looks like it just may be a bit laggy. Again its probably something a bcm flash to the 09.5 spec could fix...
                I am almost ready to do this swap. Any more information on this swap? Do you think the 2009 bcm flash could fix it for sure?
                  Nah I don't think there's any other info. I really won't know if the bcm flash will fix the little issues for sure but it probably wouldn't hurt more than your wallet to try.
                    Which is the best option to go for the flashing of the bcm: dealership, WAMS, or do it yourself tech? Thanks CrusinG6 !
                      Not sure. I guess you could call a dealer and see what it would cost. The wams tune gives you a chance to change some things. Like the DRL or remote start.
                      I'll keep an eye out to see how yours comes out!
                        Dealer cant do it so I can save you that call.
                        Chris White
                        http://www.GTOShiftLight.com
                        2006 Spice Red GTO - Stock
                        2012 Cherokee SRT8 - Stockish
                          Awesome ! Looks like I will be considering your business Chris.
                            I'm going to try it soon. The seller sells the Speedo cluster after the first of the year. So I will get it soon.
                              Cool! I have the money to buy the cluster now. Can I send in a bcm from another G6?
                                How much for a flashed bcm for my 2008 G6 GT 3.5 with these instrument cluster issues fixed? I have the money to buy the speedometer now. And also, how much more to turn on remote start?
