got this bad boy in may of 2009 and until now I never really got into deciding what mods to do to it. I just love the white, know what I'm saying! I first started using Royal Purple Oil for my cars oil from the first oil change and I used the same brand for my first transmission flush as well. I love that oil!!
Photo of my first custom touch. I put the vinyl on myself! That's my nickname! The floor mats were my second addition. They are the red outline with the Pontiac emblem and the model name on them.
My second touch was the LED bulbs in the front R and L Door Pockets, in all four door handles and under the dash on the R and L, and under the front seats, and finally in the front grill to give it the effect of a beast under the hood! That square red button turned 90 degrees, that turns on my LED Bulbs.
The Third touch was VHT painted headlights and tail lights. UV protected clear coated for the headlights and tails as well.
All four calipers have purple high temp paint on it. Love that purple!!! But, not that light purple crap, like a lavender. Only the dark Purp for me!!
The Fifth touch was this streamer for the trunk. I am a mechanic for the Air Force, and we put these on the jets when they are being worked on to make sure safety devices are removed before the jet goes for a flight. I also thought it was cool because there is a personal aircraft called a "G6". So....why not, right?!
The Sixth touch was having a professional paint my trim. I never had a lot of room to do this nor the place to do it at. I did paint the steering wheel trim up myself! I used House of Kolor Pavo Purple with red flakes for the steering wheel trim paint. The others trim pieces just got a pavo purple that is their shimmer line of kolor. Though the light reflects my steering wheel column over my Manual Transmission gear displayed and I sure cant see what gear I am manually shifting towards. That's okay, Ill figure that issue out.
This was my Seventh touch, repainted the face cover for the stock GT stereo the same as my interior. I love it!!
Eighth touch was my own fabricated USB for the vehicle. I replaced the 12Volt cigarette style plug in with USB. I just tapped into the already existing 12volt wire and wired up all 6 USB ports.
Replaced my radiator with a Silla!!! Love that New Aftermarket Product Smell!!!
That is my energy suspension outer tie rod boot. I just ripped off the old boot that was rubber and put this bad boy polyurethane on! Next is the other side when it goes dead!! It took me some peeling off of the old rubber for this to seat all the way onto the metal ring that goes around the tie rod.
**Next up is my Max Advanced Black Zinc Coated Cross drilled and slotted rotors installation. I have them already, but the rear rotors are being resent to me to replace the rear rotors that have the missing zinc coating. There was rust already in between the discs of the rotors. I cant wait to get them!!
**Update**
I received the replacement rotors and they look better on their coating of black zinc. I have done some unexpected maintenance and she has a New high pressure power steering hose and I am just waiting on my power steering outlet hose to come in.
I put in some h11 cippa blue low beam light bulbs to help shine up the road better. I also installed blue LED bulbs in a circular pattern around my fog projector lights. These will be used for a blinker.
I run royal purple power steering fluid and I have been running their xpr motor oil and have been running their Max ATF tranny fluid as well. I also run their oil filter too as well.
Now can you all guess my favorite color. I'll give ya a hint.... Its Royal...
New update! I just got me delivered my New Anzo projector headlights tonight. So Now bye bye stock look! So that left me with those cippa evo formance low beams bulb to now go into my fog projector housing. The housing of these headlights say Eagle Eyes. I am installing these tomorrow. I have to repair one of the mounting tabs. So I will need time off for the day to fix it. These are sexy in person. I'll give that to Anzo/EE.
12000k 35watts low beam HID. Its beautiful at night with them! I had to swap the 55 watts for the 35 watts. Its the same kind, look, and style ballasts though.
10000k Autovizions non-slim ballasts and on a side note, they fired up right away at that.
***New update***
Bought me a voltage stabilizer for the electrical system. I had some money saved up to try it, so why not. Here it is.
it blinks to show that it is on.
New appearance update! I put some green all on the front of the 6 now. I also added some LEDs behind the projector lens. My eagle eyes now have evil eyes. I love it! I'm going to have brighter LEDs there soon so it shows up better.
But for now, here they are.
I felt that the front should be all green....and sooooooo did the cop with his warning about that I can't have blue around the fogs. He said that he knew I was local and seen my g6 before. it looks better though. Here it is:
New update: took off the green and purple LEDs behind the projector glass that I was experimenting with. I also added load resistors to my taillight blinkers. So no more fast blinking. I think it was going to drive me crazy
I painted up my dome light flat black and purple. I will work on the others here tomorrow.
I also painted up the map light/on star microphone trim a flat black and purple. Just like the dome light. Now, I just have to do something about that headliner. That tan color sucks.
Got me some stealth blinker bulbs. They are painted with translucent chrome paint.
With Amber bulbs
Without Amber bulbs, but with the stealth bulbs!
**Update** I have a racingline strut tower brace from a former jeep owner that used to be on our site. He sold it on eBay for 50 bucks with 16 buck shipping. Thanks to him, I can make my suspension plant to the ground better. Yay!
**Update**
Just installed the stb from Racingline:
I will report back on how it feels. Can't wait!
Thanks for looking
**Update**
***New update***
With Amber bulbs
**Update**
Thanks for looking
