Another Recall for the G6 5/2014
  • Another Recall for the G6 5/2014
    Clicky Here
    Wiring for Brake lights, sounds like a faulty brake pedal position sensor to me..
    also make note of the truck recall
    Re: Another Recall for the G6 5/2014
    This has been a problem for years and they only recalled a few, it's about time they get the rest. Mine started doing it again for the third time, problem is there is no ultimate fix. They just keep lubricating the corroded piece in the BCM but eventually it happens again. I have all the symptoms - brake lights stay on and work opposite, hard to shift out of park, cruise control/traction control/stabilitrak all disabled. Obvious safety issues here, makes me less sad to be selling the 6 after all the work.
    Current: 2015 Volvo s60 t6 awd r-design platinum
    Former: 2006 Pontiac G6 GTP 3.9L Sedan Silver loaded w/ GT-R Exhaust, CRABS CAB Intake w/ FPU, AIT Carbon Fiber hood & roof wing spoiler, GM Ground Effects Kit, Eagle Eyes black CCFL halo projectors, 18" Konig Airstrike rims, shadow chrome recessed upper/lower grilles, 35% tint all around, tinted tails, Kenwood Excelon X497 Head Unit, R1 concepts drilled/slotted rotors, silver door plate sills, Racingline STB, Bridgestone Potenza Pole Position tires, custom GTP floor/trunk mats, gm carbon silver interior trim kit, CF dart & pillar overlays/plate bracket, rs-1 cf/silver pedals, red calipers w/ GTP logos, chief badge replacements, red/silver painted engine/battery covers, windshield washer relocate
      It's just weird since I never have any problems with it though..... the only problem I have right now is just to replace the engine mount since the engine moves when shift from park to drive and then recently my turning signal switch wouldn't turn back to it's original position....
      http://viewmorepics.myspace.com/inde...mageID=1623464
        I've had this issue twice.. It's an easy temporary fix, cleaning & greasing up the BCM. The dealer wanted to change the whole BCM unit for an absurd amount of money.
        Mods: Crabs CAB w/ FPU, GT-R Exhaust, Racingline Strut Tower Bar, KYB schock/struts, EBC Rotors w/ ceramic pads, Aftermarket Sound System
