has anybody gotten the letter lately for this recall?
I am waiting for my phone call from the dealer.. The service dept. said they would call me the minute it became available.
I was told on the 8th that it would be 14 days.. idk if thats working days or calendar days. but that puts the timeframe from the 22nd-28th is the likely result. Regardless, June 2nd you should be able to call and schedule your service.
No.. I'm waiting BC the dealers have to have a program in place to order parts and be reimbursed for the service work. It has nothing to do with other recalls. Recalls are announced when they are determined to be at fault. The service work begins once they have a program in place. This is NOT an over night task. We just have to have patience.
sent via space transponder
I just got this recall a month ago (and the brake light one). Both letters stated that parts are not yet available and another letter will be sent once they are.
Any idea how long the work will take?
Vector Tune - CRAB Cold Air Box - Cquence Ultima Cross Brake Rotors
