Clips needed for Chrome Lower Recessed Grille 2008 G6
  • Clips needed for Chrome Lower Recessed Grille 2008 G6
    I have the OEM recessed chrome grilles on my 2008 G6 V6 SE. My right lower grille was very loose last Fall and I've spent months trying to find replacement clips to put it back on. The clips were all rusted. Here's a picture of what they look like and what they should look like. Any tips on where to buy them?
    Re: Clips needed for Chrome Lower Recessed Grille 2008 G6
    I bought them at an auto body supply store... I have more than plenty.. i can send you what you need if you'd like. They were expensive.. like $1 each :/
    sent via space transponder
      That seems excessive. I'm checking on some other stores as well as some of the big sellers on ebay. I emailed customer service at http://clipsandfasteners.com to see what they can do for me. Thanks for the offer I'll let you know if I'm having issues.
        i can get you the part number when i get home tonight
          Any luck figuring out the part number?
            Yes I'm resurrecting my post. I had them attached with foil tape which worked for a while but my Dad hit a snow bank and the two grilles came off. I found what I think is the correct part available to purchase in bulk.
            The question is which panel thickness is correct:
            (larger Tinnerman U-Clips Panel Thk 0.320-0.340)
            OR
            (smaller Tinnerman U-Clips Panel Thk 0.245-0.255)
              2007 G6 GT
              Debadged, CF Overlays, 5% Tint, Tinted Tails, Upper And Lower Recessed Grilles, Eibach Lowering Springs, Painted Calipers, Cross Drilled And Slotted Rotors, K&N CAI W/ CRABS, Tiger Crab, GTR Exhaust, WAMS Tune, Racingline STB, Grounding Kit, and Street MMI's, Redline Quicklifts, Eagle Eye Halo Headlights, Interior LED's, 5K HID'S Lows / Fogs
                I'm going to just order them since they are so cheap. It looks like a total of 16 are needed (8 each). Maybe it is 6 each. Guess it couldn't hurt to have a few extra. Though I probably won't have this car long enough for them to rust again!
