Hey all! I just wanted to let everybody know that I've got the perfect measurements for the cuts to make to the projector's shroud to make it fit the best. I'll be updating this thread within a week with more information.
Both housings will be converted to an HID projector setup.
Well i mean like each headlight has two bulbs in them im not sure if its like a high and low or something but as of right now in ur picture u have the left converted and the right still a normal headlight
Well i mean like each headlight has two bulbs in them im not sure if its like a high and low or something but as of right now in ur picture u have to left converted and the right still a normal headlight
That's because I wanted to figure everything out on one light before I start messing with the other. Both housings will have an HID low beam and a halogen high beam. FYI: The projector will be wired to have a functional bixenon function, meaning it will serve as both a low beam and a high beam.
If you buy a retrofit kit, it only comes with 2 projectors, plus the bulbs, ballasts and shrouds. If you want to do your high beams as well, you need 2 retrofit kits.
Correct. That's only if you want quad projectors and HID high beams though.
