Flashtech LED Angel Eyes
Re: Flashtech LED Angel Eyes
wow ima tard.. there is an adjustable trim pot on the back side of that board.. didn't realize it was an adjustable voltage regulator.. problem solved!!
Originally posted by cmessick View Postwow ima tard.. there is an adjustable trim pot on the back side of that board.. didn't realize it was an adjustable voltage regulator.. problem solved!!Eagle Eyes Projector Headlight Retrofit: http://bit.ly/QKH9rY
Originally posted by cmessick View Postwell. maybe i spoke too soon.. trim pot has no effectEagle Eyes Projector Headlight Retrofit: http://bit.ly/QKH9rY
