cadillac cts 400+ hp
  • #16
    Re: cadillac cts 400+ hp
    Originally posted by auquier View Post
    I'd be all over the ATS-V or possible ATS-V+...
    V= 425hp TTV6 with the 7sp MT or the 8sp AT..
    V+= rumored V8...
    You kids like the Cadillac ATS? Yeah, I do too. That's why I'm pumped for the V version. GM wouldn't confirm it during the Detroit Auto Show, but it's in the cards, and know we have some possible details about its power and transmission.
    • #17
      So I found this cutaway of the engine. As I was intrigued about the exhaust setup into the turbo.
      • #18
        And the top mounted throttle body...
        CRABS WAMS MPD GT-R Brembos and stuff
        • #19
          The charged air volume is only 20% of what's normal.. this allows the two smaller turbos to build HIGHER pressure than larger turbos in a traditional setup..
          The TB is on top under the intercooler... this is a fairly complicated and very compact motor. GM squeezed a bunch of tech and engineering in this one
          sent via space transponder
          • #20
            It sounds to me they did some research on a wrx motor aside from the turbo setup it sounds too similar to a wrx.
