What was Lampoon doing in Colorado???
  • What was Lampoon doing in Colorado???
    http://denver.cbslocal.com/2012/08/1...miles-on-i-70/
    Re: What was Lampoon doing in Colorado???
    .... .. i see no connections..
      Blue G6 driving fast.... oh never mind......
        . I get it...but still no connection...
        MY PROGRESSION:
        http://www.g6performance.com/forum/showthread.php?t=20385
        Mods: Classic Performance Exhaust, WAMS 93 Octane tune, Crab Intake, and a whole lot more...
          hahahahaha.. neat story tho.. guy did the right thing
            Sure this thing wasn't a toyota?
            2009 Ford Mustang Premium Pony 4.0L
            2001 GMC Sierra SL 4.3L
              I would have gotten away.....
                How can people not figure out neutral? Car won't stop accelerating, easy slap the shifter forward and turn the key off. Coast to safety.
                ISimple Ipod adapter, Heat wrapped Injen, CRABs Option 3, ?% Tint, 6000K HIDs,GT-R, Tinted Tails, Rear badge delete, Plastidiped grills and front dart, Brembos, Pulse p5 17"s, racingline MMIs
                  If you read the comments posted by the news company, they mention that he tried turning the car off and moving the shifter, neither worked. Hence why you should just buy a manual instead of an automatic. But I guess even those are computerized with hydraulic pumps... better yet get an older car that still has a cable driven throttle and either direct or cable shifted manual transmission.
                  Or you can wire up a kill switch on the signal wire that goes to the fuel injectors..
                  My Progression
                    Either way the clutch is not coputerized. Hydraulic pump doesn't mean that its computerized. or you could just rip it out of gear. that is physically linked to the tranny.
                    MY PROGRESSION:
                      Wow that is wildd
                        Why can't Darwin win for once with these idiots.
                        TURN THE KEY OFF and hit the brakes. If you have a physical key, and take the key out of the "run" position then power to the PCM will die and you will be left with a car that eventually will coast to a stop on its own due to engine drag. Then use the brakes with the vacuum left in the system to stop the car.
                        It works on my G6, it works on my TransAm GTA, it worked on my 99' Kia Sephia, and it worked on my 93' Ford Escort as well. It also works on my friends 06' G6 GT A4.
                          Idk about you, but my G6 won't release my key if the transmission isn't in park.. From every incident I've seen like this, the driver has tried everything suggested by both the police, and the manufacturer (through 911 dispatch). I'm still saying installing a kill switch to cut the power or ground to the battery would do the trick.
                          My Progression
                            Just turn the key off or god forbid just put it in neutral LOL
                            Chris White
                            http://www.GTOShiftLight.com
                            2006 Spice Red GTO - Stock
                            2012 Cherokee SRT8 - Stockish
                              You don't need to remove the key from the ignition, that would lock the steering column and THAT is bad. Just click it to "ACC" which is 1 click counter clock-wise. This shuts down power to the PCM. No PCM power, no ignition. Its that simple in the G6. As long as the key is not in "LOCK" then the steering column and shifter will remain unlocked.
