I used to be a member of a forum that had a member kudos spot under the screen name in their posts. Basically what it was about was people post stuff (i.e. information or how to) and other members could give them positive or negative kudos. Members didn't get anything it was just a fun thing to do.
Member Kudos
Tags: None
Re: Member Kudos
if you look under the member info on the side of each post.. there is a star you can click to add/remove reputation..
Re: Member Kudos
This forum has that.. under where it list the type of car/color, there are the two little symbols. It's the star one, it add reputation to the person.
edit; Posted at the same time as cmessick..*Performance
CRABS o3, Custom Magnaflow Exhaust, WAMS Performance tune, Racingline STB
Exterior
Platinum Apex Rims ( 18x8 ), Hankook v2 215/45R18, Painted calipers (Red), Complete debadge , Handle Overlays (Gloss Black), Arrow Overlays (Gloss Black), Grille Lighting (White LED's), Tinted Tails (2 coats VHT Niteshades), Painted Battery Cover (Silver with Red), Painted Engine Cover (Silver with Red), Eagle Eyes Projector Headlights (Black Housing), Upper Recessed Grilles, (Chrome)
Audio
2 12" Memphis Subs (15-MCP12S4)
600watt Sony X-plod Amp
On the list:
Window tint
Glasspack
Re: Member Kudos
my bad... I see it now. It is hard to see on my computers... POS..Guess I will mess with the brightness and color settings.
Re: Member Kudos
Click on "Notifications" at the VERY top of the page.
