Transmission Compatibility
Show: GXP Hood - 2009.5 Front Bumper & Rear Spoiler - Black Housing Headlights - White LED Reverse and License Plate Lights- White LED Interior Dome & Map Lights - Matsushita Gen4 6000K HID Lows - White LED Fogs - GXP Rear Bumper - White LED KPH Instrument Cluster Conversion - 15% Tint
Go: CRAB + FPU Powder coated wrinkle black - Racingline STB , MMI & Grounding Kit - Dash Hawk - Front 4 Piston Brembo Brakes - Rear Cobalt SS TC Brakes - BMD Stainless Steel Braided Brake Lines & Endlinks - WAMS 93 Tune - Custom Magnaflow Exhaust - Milzy Motorsports Headers
Progression Page: http://www.g6performance.com/forum/s...ad.php?t=22818
http://www.cardomain.com/ride/2594110
Re: Transmission Compatibility
I realize tgis thred is old but I was curious on trans compatibilty between engines I.e. 6t70 bolt to a 3.5? Shear curiousity....what about the 4t45 and the 4t65? Interchangeable? Looked and searched but couldnt find, sorry if its a repost. Thanks!
Originally posted by HJJ103 View PostI realize tgis thred is old but I was curious on trans compatibilty between engines I.e. 6t70 bolt to a 3.5? Shear curiousity....what about the 4t45 and the 4t65? Interchangeable? Looked and searched but couldnt find, sorry if its a repost. Thanks!
Im going to preform CPR and bring this thread back. I have a 06 GTP with a 4t65 trans. My trans is going out and I have about a month left. I was looking at getting a 6t70 or 6t75 which ever will fit. Can anyone confirm that it will work and fit?
if you throw enough money at it.. it will work and perform flawlessly
The bolt pattern should be the same. Need someone to confirm. The biggest problem is the programation. Plus, the 6 speed trannies has an integrated TCM (I think) versus the 4 speed trannies that has an external TCM located somewhere else in the engine bay. I don't know about the compatibility of the flywheel and the input shaft.
