Transmission Compatibility
    Re: Transmission Compatibility
    Originally posted by SexyG6 View Post
    ya yours is a sealed trans, and your case isnt as beefy as mine id know as i put ur mmis in and the tcm controls the shift speeds so gear ratio wouldnt nessisarilly affect the shft speeds...... not to mention as i stated i confirmed thru serial number mine was indeed a 6t75 with the 70 differential......as the 70/75 has the exact same gear ratios the only difference is the 75 is stronger and has a 3.16 differential rather than a 2.77
    what is your trans out of?
      g6 gxp its my stock trans ive had it on no tq managment for 300+ track runs and about 40k miles with absolutely no problems at all
        I realize tgis thred is old but I was curious on trans compatibilty between engines I.e. 6t70 bolt to a 3.5? Shear curiousity....what about the 4t45 and the 4t65? Interchangeable? Looked and searched but couldnt find, sorry if its a repost. Thanks!
          im pretty sure their not.. but these guys can confirm that.
            Im going to preform CPR and bring this thread back. I have a 06 GTP with a 4t65 trans. My trans is going out and I have about a month left. I was looking at getting a 6t70 or 6t75 which ever will fit. Can anyone confirm that it will work and fit?
              if you throw enough money at it.. it will work and perform flawlessly
                The bolt pattern should be the same. Need someone to confirm. The biggest problem is the programation. Plus, the 6 speed trannies has an integrated TCM (I think) versus the 4 speed trannies that has an external TCM located somewhere else in the engine bay. I don't know about the compatibility of the flywheel and the input shaft.
