theshibbykumquat's Progression (Brembos Pg. 2!)
    Re: theshibbykumquat's Progression
    Looks super! Have the springs settled at all?
    CRABS WAMS MPD GT-R Brembos and stuff
      Thanks! And yeah they definetely settled a little bit, I got get a better picture up at some point. Only about 2 fingers of gap on all 4 corners.
      My Progression
      BMD Performance products
        O_o Sounds baller! Can't wait to see these updated pics! Also them Brembos are gorgeous! I am sssssoooo jealous! I want them so bad!
        My Progression---------------------Crimson Crusade---------------------Why Do I Run?
        Originally posted by wzbhnn
        We all like different looks, that's why we mod!!
          While everybody else was out shopping yesterday, I finally had some time to throw on my Brembos! And lots of pictures for you guys!
          I like how the painted spacers peak out if your at the right angle. If I have to get spacers down the road I'm painting them. Thanks for the idea.
          Why is Divorce so expensive? Because the Hitman won't take Plastic.
          Eycman's G6 Progression
            WTH is this?
              Originally posted by cmessick View Post
              WTH is this?
              Its a secret for now ;-)
              My Progression
                Ets not a seKret ifs I canz seez it!!
                  Bryant,
                  if I'm driving down the garden state and I drive up onto your ass and a retractable "get off my ass fucker" flamethrower pops out of your trunk I'm going to be so pissed! - I thought of that idea 1st!!!!!
                  but it's nice to see R&D is still kicking...
                    did you paint the calipers with a spray can? i really like that color.
                    ______________________The Untouchable!____________________
                      Gosh dangit! No fair stealing my blue calipers! Now my crappy stock pretty blue is going to look like crap next to your pretty BREMBO blue lol. Looks very nice man.
                      2008 G6 GXP 3.6L Coupe - Street Edition - Black
                      Mods: All the usual suspects
                      Progression Thread
                        Yupp, i think it came out pretty damn well for a spray can. Duplicolor engine enamal (ceramic stuff) for the primer and clear, the color coats were with duplicolor metalspecks blue.
                        Prep and patience was key though. Sanded them down with like 600 grit, then wipe down with denatured alcohol. 2 coats of primer with an hour between. Let the primer cure for 72 hours. 2 coats of color with an hour between. Let the color cure for 72 hours. Then 2 coats of clear with an hour between. Let that sit for 7 days before applying decals and installing. The finish came out super hard from the ample curing time. Took about 2 weeks in the making, but i thought it was well worth the result.
                        My Progression
                          I hope it holds up well for you after all that work. I took my time and the first time I had to take the calipers off I got chips in the duplicolor. I broke down and am getting powder coating done as I type this.
                          Progression Thread
                            Yeah I was thinking that also, I guess Ill see how they do. For the $25 in paint though i figured it was worth a shot even if it only lasts a year or so. If they start chipping though Ill likely just go the same route and get the powdercoated
                            My Progression
                              that was the metalspecks? it looks good. can i get a close up shot showing the specks/flakes?
                                Yeah lemme dig through my camera as i took a bunch more, and there must be some closer ones on there somewhere. I really like how the color came out by the way, in the sun the metallic looks awesome.
                                Edit...
                                Found some pictures from closer up, lemme know if you want some closer ones or something and Ill snap them this weekend...
                                My Progression
