Re: Deathmage's G6 - Brembo's and Spacers Installed - Koni's Full Conversion Install
it's offical. Replacing Shela with a 2015 WRX STI. It's been a really great ride, but she has 235,000 miles on her and she is starting to having coolant issues. I guess all good things come to and end and the torch is passed on to the next ride. She's been loyal and true right up until the end. She has been the best car I've ever had, she never stopped turning me on and if she didn't start having a coolant problem I'd drive her until 1 million miles. I may still keep her instead of trading her in and replace the head gasket. Maybe it won't be the end for Shela, but she needs to be given a proper rest for a while.
Thanks everyone for great memories.
I hope learning stick won't be to dreadfully hard. ;-)
Performance: WAMS, K&N 69 Series CAI, Custom Magnaflow Exhaust built with a Camaro SS Muffler and Glasspack with 4 inch double-wall stainless steel tips, Thunderbolt 8.2mm High-Performance Spark Plug Wires, NGK Laser Iridium Spark Plugs, Pennzoil Ultra Full Synthetic, Resonator Delete, Racingline Motor Mount Inserts, Racingline Grounding kit. (4 additional grounds from battery to front bumper for DDM tuning HIDS)
