Deathmage's G6 - Brembo's, 19mm Spacers Installed - Koni's Shock Conversion Installed
    Re: Deathmage's G6
    Just went to get my car washed and waxed. I figured I'd take some pictures while it's nice outside.
    The HID's in the fogs show up fine, not so well in the low beams, but you sorta can tell because there blue and not yellow as Halogen bulbs are normally...
      Re: Deathmage's G6
      Originally posted by SkinnyPete View Post
      That's not a Sentra dude.
      oops your right that's his Maxima. I gotta take a pictures of his V-spec Sentra, it's sick. He's got a ECM chip and he Turbo'd it. it sounds sick, it hums wonderfully! he's got dual Optima batteries and a killer sound system. He's from Jamacia, very cool guy, one of the electricians from my job. He wired my HIDS for me with the custom relays and think ground cables.
        Re: Deathmage's G6
        Nice I would like to see it. He will get more power and reliabillity out of his setup if gets a dyno tune as opposed to the chipped ECU.
        07 G6 GT Progression [traded]
        05 Sentra S-ER Spec-V Progression
          Re: Deathmage's G6
          I'm not sure what he's got done other than the chip and the Turbo, that's all he's told me about, he's got dual Exhaust. ya next time I stay after 5pm I'll go see what he bring to work at 6pm. He lives in the Bronx's in NYC.
            Re: Deathmage's G6
            Just ordered a new set of Michelin Pilot Sport A/S Plus tires. I've enjoyed the handling and performance for the past 12 months, and even though I've only gotten 35,000 miles out of them. I normally drive 2400 miles a month, so I think the 45,000 mile warranty doesn't apply to people like me that drive as much as I do...
            Next modification will be the Magnaflow Cat-back Exhaust.
              Re: Deathmage's G6
              If they're anything like the Summer Pilot Sport PS2's they'll be good tires. Mine on the GTO handled good in rain. As expected with summer only, horrible in Snow... got caught in the freak October foot of snow storm with my pants down with summers still on and had to ditch it in a parking lot and call for a ride..
              2005 CGM GTO.
                Re: Deathmage's G6
                There amazing tires year round, haven't had one problem with them. they hug corners flawlessly, and handling and ride comfort is amazing. braking is wonderful. it laughs are rain, but heavy snow watch out. Light snow it does fine, just not heavy snow. if our cars had AWD might be different. my friend has a 328i x1 with them and it laughs at snow....
                  Re: Deathmage's G6
                  Quote Originally Posted by theshibbykumquat View Post
                  Couple things going on with the stock damper. The eyes on the stock damper are made of soft rubber bushings. The damper itself is made of plastic and can easily be moved even with your hand.
                  The brace is meant to replace the stock damper. The soft bushings are replaced by the same heavy duty rod ends as our endlinks, and the plastic damper is replaced with a solid link with adjustable preload. Brackets are made of hardened 5052 aluminum alloy that is then powder coated. Basically it provides a solid feel with the engine, eliminating drivetrain slop, smoothing out shifts, etc. Can be used on its own or as a complement to MMIs to firm up the engine further.
                  Engine brace is still a couple weeks away atleast. Still quite a bit of testing and revisions are needed on it. Stainless lines however are looking at a release early next week!
                  I guess getting these MMI's installed has more of a purpose now. I just order the MMI's and grounding kit from Taz this afternoon.
                    Re: Deathmage's G6
                    Getting my tires installed today, they arrived on Thursday night.
                    Their my second set, I really like these tires on my car, for around 190 each their a bit pricey, but they perform.
                      Re: Deathmage's G6
                      I just installed the BMD endlinks yesterday morning wen I had the new tires installed. I must say I only drove it a bit with the new Michelin Pilot Sport A/S plus tires today with Nitrogen and the STB and endlinks feel more fluid in turns, almost like they got married and had amazing sex! - it feel that good!!!
                      I was able to turn quite sharp at a 4 way intercession, surprisingly better than before without them and zero left to right body motion. I'm interested to see how much more stability lowering the car would do for the handling. People look at me as I did a 5 second whip turn with nearly no body roll, it was amazing.
                      Overall I'm quite happy with these endlinks. I wish I took pictures when I had them installed.
                        Re: Deathmage's G6
                        I decide to take some pictures after washing my car and applying 3 coats of wax. I used my brand-new Canon EOS REBEL T3i/600D Digital Camera.
                        One of my many hobbies and pass times is photography, I plan on take a few more shot of the car in it's natural habitat, the open road in the country.... I want so shots near a car, in a majestic arch of Oak along a side country road with cattle in the background.... I'll have more in the coming days, this week is my vacation from work.
                          Re: Deathmage's G6
                          old post, deleted.
                            Re: Deathmage's G6
                            old post, deleted.
                              Re: Deathmage's G6
                              very nice dude
                              Get out the way!
                              to many things to list and also change my mind way to much to actually tell people lol
                                Re: Deathmage's G6
                                I am puzzled, what is the single nut for?
