Am missing somthing, whats the MMI mean? I cant think todoay what MMI could even be
2006 G6 GTP: Traded
2013 Mustang GT Gotta have it Green color
Brembo brake package
420 HP 5.0L
Ford Racing Power Pack
(ahh beaten to the punch)
That would be Motor Mount Inserts
Ive had that happen recently in another forum about some companies that make under-drive pulleys.
He's kidding!!!
2012 AWD Fusion Sport...
Steeda springs, Steeda STB, Steeda Motor mount, Steeda Intake, Steeda 93/100 octain tune, Steeda TB spacer, Magnaflow catback, 19x8.5 mustang GT wheels painted body color, 5% and 35% TINT, upper and lower 6,000k HID's, Steeda Hood struts, and tinted tails, and much more...http://www.cardomain.com/ride/3974935/2012-ford-fusion/
I wonder if this will be a re-visited topic when BMD makes the engine damper out of aircraft grade aluminum. I still think having the MMI's a must though, kind of makes logical sense.
for those that have race series MMIs, getting a new damper will not do you any good other than to add un needed weight...... with the race mmis my engine doesnt move AT ALL even with the damper completely removed, i took it off at 36k miles when i spun a rod bearing and pulled the engine and never put it back in, no have 68k on my black gxp and zero issues without it missing, and the engine still does not move AT ALL with just the race MMIs
It's probably more of a mental thing.... metal is better than plastic
Mine went on with a little bit more effort than I was expecting. I also noticed recently that its has broken. Not broken completely or come disconnected but internally its snapped not putting and opposite pressure on the brackets. I also have the street MMI installed at the same time so I would think that would extend the life and reduce the load of the torque dampener part. If I have to replace this before trading in my car I will probably just reinstall stock dampener.
