Hi,
I am looking to add cruise control to my 2008 G6 value leader. I have read using search and realize it is not as easy as buying a new steering wheel and just plug and play possibly re-program.
So, I already have a steering wheel with controls and everything from a friend's G6 that bite the dust. So, it is my understanding from what I have read that there are no wires for cruise control that goes to the connector on the steering column. After checking that is true, only 2 there which i assume is for the horn. Based on the wiring diagram I have from the Haynes manual there are 3 wires, Pink, Gray and Light Green that go from the BCM to the Air Bag sliding contact in the steering column.
My question is, do you think it is possible to just run those wires from the BCM to the connector and get the pins or sockets needed to add them to the existing connectors? Or is it completely different wiring and connectors on the BCM for the cruise and non-cruise control?
I assume I can get power (Pink wire) from really any source along the way to the BCM, but I need to know where the other 2 go. Does anyone have a wiring diagram or connector pinout for the BCM?
Thanks for your help. If this turns out to be something that can be done, I will put a How-To together if there is anyone else that wants to add cruise control to a value leader.
