Altered6 Progressions - Baer Cobalt 13" Brakes
  • #91
    Re: Altered6 Progressions
    please get a full pic omg they look sweet
    • #92
      Originally posted by Altered6 View Post
      Was sitting in the garage watching a storm blow in and teaser.
      Wow! - Altered6 that like changed the whole look of your car man! - spacer look so mean on your car! - makes me want mine sooner. - any rubbing?
      BTW - did you get the tracking info?
      • #93
        Thanks guys!
        Originally posted by Deathmage View Post
        Wow! - Any rubbing?
        No rubbing issues. In fact, when the time comes I will be considering wider tires.
        Check PM's and your mailbox. USPS shows they were delivered today and Canada Post guarantees delivery by tomorrow. Please tell me you received the Eyelids this time...
        245/45/17 Bridgestone Potenza RE-01 R, 245/45/17 Bridgestone Blizzak WS60, Eibach springs, Debadged, Recessed upper grills, GTP rear valance, GXP exhaust, Redline Tuning QuickLifts, K&N air filter, GMPP strut tower brace, Steering wheel stereo controls, Baer Cobalt 13" front brakes, Cobalt SS 11.75" rear brakes, Stainless steel braided brake lines front & rear, Leather steering wheel, Recessed lower grills, Leather shifter handle, Leather parking brake handle, Leather console lid cover, Volant intake, PIAA H9 & H11 Xtreme White Plus headlights & driving lights, 93 octane tuned ECM & TCM, Custom painted headlights, Motorsport Tech wheel adapters, C5 Corvette 17" x 8.5" wheels, Koni Sport struts and shocks, MSD 8.5mm Super Conductor plug wires, Racingline polyurethane motor mount inserts...
        Altered6 Progression Page
        • #94
          Altered, do you got a side picture shot? - I'd like to see what they look like....
          • #95
            Sorry DM, I didn't get any pictures of the Corvette wheels on my G6 before Winter rolled in and the Winter wheels will be on for a few more months before it's safe to switch them back.
            Here are the specs of the wheel adapters I have if it helps any.
            Motorsport Tech
            Purchase Wheel Adapters
            Wheel Adapter Configuration - Complete!
            2007 PONTIAC G6_BASE_-GT
            Your Bolt Pattern: 5x110mm
            Your Hub Diameter: 65.1mm
            Type: One Piece Adapter
            Hub Centric to Car & Wheel Centric to Wheel
            Thickness: 22mm
            Stud Size: 12x1.5
            Center Bore: 70.7mm
            Diameter: 5 by 120.7 (4.75 inches)
            Quantity: 4
            • #96
              While surfing the interwebs one nasty Winter weather day I found a deal on a G6 instrument cluster that was too good to pass on. The only difference between the existing cluster and the new/used cluster is an 8000 RPM redline because... Well, you just never know what the future may or may not hold.
              Before
              After
              The new/used instrument cluster is plug and play. As you can see the mileage is not stored in the cluster.
              • #97
                Re: Altered6 Progressions - Baer Cobalt 13" Brakes
                Stored in the BCM. Mine goes up to 8k! But its not the Canada spec one.
                I'd love to get my hands on an 09.5 cluster.
                Looks good though. As if it came with your car ha
                • #98
                  Why did they make two different tachs? I4 vs. V6?
                  • #99
                    So i just recently bought my G6 and have been looking at what kind of worth while mods are for it. Every time i look at someone who has really modded out their car i get to the end and it was last posted in years ago and i was quite delighted to see that you still own your G6 from the looks of it.
                    • Re: Altered6 Progressions - Baer Cobalt 13" Brakes
                      There are actually three different tachs for the G6, 6500, 7000 and 8000 RPM. Not sure why GM would bother making more than one.
                        Can finally cross this off the To Do list.
                          Those wheels look so good man, I can't wait to see a pic of the whole car!
                          Techno gray 07 G6 GT Sedan 20% tint, 6000K HID's, red LED floor lights, intake resonator removal, LED interior and reverse lights, debadged rear dart, gm emblem and pontiac emblem, and black emblem overlays.
                          Build thread: http://www.g6performance.com/forum/s...ad.php?t=24478
                            Thanks!
                              So when we getting a full car shot with the vette wheels?!?!?!
                                No kidding all these little things you have done make me like!!
                                2001 Oldsmobile Alero GLS 3400, F40 sedan.
