Full Bolt On 3.6 Dynojet Run
  • Full Bolt On 3.6 Dynojet Run
    This is my dyno after the rebuild (again) caused by somewhat unknown circumstances. Mods at this point are FWI, ported upper/lower intake manifold, ported heads, manifold spacers, MMS headers, and cat-back exhaust. Also added was a Powerbond UDP.
    Unfortunately, I wasn't there for the tuning. So I have no vids. But here is the graph. It has the previous dyno, minus full exhaust and UDP, overlaid with it.
    Note the temperature that this was done at. Wonder what some cooler weather would bring. ;-)
    Born: 2/16/2007 -- Best Time: 14.20 @ 98.61 MPH -- 240 WHP & 205 WTQ -- Blueprinted and Balanced
    - U.C. Tinted Tails - Dr. S Stage 3 - SRC Dyno Tune - Eibach Pro Kit - C.I. FPU - Scuba's Aux. Retrofit -
    - 08 SS/TC Brembo Conversion - Ported Heads & I.M - MACE I.M.S. - RacingLine MMI - O.T.T.P. SRS -
    - MMS Headers - ClassicPerformance Exhaust - Powerbond UDP - CF Catch Can - Racingline Strutbar -
    Re: Full Bolt On 3.6 Dynojet Run
    I don't really know what I'm reading, so I'm guessing you're HP is 236 and Torque is 205, or close to those numbers.
    Questions:
    1: Are you satisfied with the outcome?
    2: Are you getting, or were you expecting more HP? (I ask cause I thought stock the 3.6 came with over 240....I'm asking cause I don't know, learning is an every day thing)
    "I put the Giggity into Each and Every Thread"
    2009 Performance Red Metallic G6, Progression Page
      Nice. With those numbers, and estimatign 15% drivetrain loss, you can guestimate anywhere from 270-280hp (Over stock 251) and between 235-245ft-lb (However, stock is supposta be 251 as well but GM could have screwed us).
      2005 CGM GTO.
        i thought the estimated whp that your mechanic said was around 300?
        Appearance: Sexy Electric Blue Metallic - 35% Tint, , Painted Calipers, Spyder Halo Projector Headlights, Red Under Dash LED's, Lower Grill Chrome Trim
        Performance: Canuck Lowering Springs, Crabs O3 + FPU, Custom Dual Muffler Borla Exhaust, Front Adjustable End Links
        Audio: Kenwood DNX5120 Double din, Hifonics HFI1000.1 Mono Amp, RE SEX12D4 12" Subwoofer (pushing 750w), Alpine Type S 6x9 Speakers, Jensen Power 720 amp
          yeah I understand why others are kinda like WHAAA??!
          You have done quite a bit of major engine modding for a 46hp gain. Who cars about crank HP, its all about the dyno HP. Did the tuner say he was completely finished with the car? I would imagine they have a little more work to do in order to get the engine with all the mods up and going like it should
            I'm still confused by this. From what it shows you either lost torque, or ONLY gained hp. That's assuming 15% loss in all actuallity it is prob a larger loss than that..
            2005 CGM GTO.
              yea i know i really do hope the mechanics can push some more power out of this
              regardless great progress man :
                do you have a full intake and a ECM TCM tune?
                  yeah I mean they really should be able to, with all those mods the gains should be much higher IMO
                    you coined out how much to gain under 50ph and a loss of torque?...
                    a before and after dyno on the same machine would have been nice....
                      that's exactly the point I'm making, spent quite a nice chunk of change. I just think it needs to be turned further. The potential is there it just has to be all worked out tuning wise
                        True I kicked out 247HP and 270Torque at the wheels
                        GMPP Cat-Back Exhaust, MMS Headers, 3" DP with Electric cutout, Full CRAB Intake, RacingLine Street Motor Mounts, NRG Engine Damper, RacingLine Strut Tower Bar, Vector 91 ECM/TCM Tune/HSRK, R1Concept Brakes, HAWK Ceramic Pads, DW's 245/45/18 with TC Wheels, Poly. Sway Bar Bushings, 6000K HID's Lows & Fogs 35watts & 55watts 6,000K Hi-beams
                        Future: Slicks for the track & Maybe alittle Nitrous
                          pic of dyno graph right now. 270 tq at the wheels with a G6?
                            Here you go
                              What are your mods????
