Full Bolt On 3.6 Dynojet Run
    Re: Full Bolt On 3.6 Dynojet Run
    91 ECM,TCM tune, Full Intake, GMPP Exhaust, Poly Motor Mounts....Didnt have headers on then but now on
    GMPP Cat-Back Exhaust, MMS Headers, 3" DP with Electric cutout, Full CRAB Intake, RacingLine Street Motor Mounts, NRG Engine Damper, RacingLine Strut Tower Bar, Vector 91 ECM/TCM Tune/HSRK, R1Concept Brakes, HAWK Ceramic Pads, DW's 245/45/18 with TC Wheels, Poly. Sway Bar Bushings, 6000K HID's Lows & Fogs 35watts & 55watts 6,000K Hi-beams
    Future: Slicks for the track & Maybe alittle Nitrous
      Impressive... I noticed that your run #5 and #1 were real close. This indicates that the dyno is consistant. Yet we dont know what kind of dyno you were on. Mustang or dynojet.
      Please read post12 from a trusted vendor/tuner overon LS1Tech.com
      Dynamometer Results & Comparisons - Mustang Dyno vs Dyno Jet - So everybody say's there is a power difference between the MD and the DJ. My question is how much? I hit 470 on a MD before my injectors, would I be able to hit 500 on a Dyno jet?
      And to the OP, albert, what kind of tuning was done? Also withthe coin toy have in that car please PLEASE invest in an oil pressure and Wodeband o2 sensor. Shit sme data logging equipment would be sweet too
      But : for getting her running again
      MAH PROGRESSION THREAD.................................................. .................................Mah Cardomain
        Originally posted by uzun1986 View Post
        True I kicked out 247HP and 270Torque at the wheels
        Very nice! Its def offical the 3.6L and 6spd is better then the 3900s The 06er GTPs got cheated!
        I would love to see your 60ft and 1/4 mile times on your car
        I have to pull out my old dyno papers but best I ever did with a CAI and PCM tune was 230 HP-ish and 225-ish torque on my 3900 GTP. I dont remember the stock numbers off the top of my head but I remember the 4spd was around a 18% drop off. Mine was done on a Mustang dyno
        2006 G6 GTP: Traded
        2013 Mustang GT
        Gotta have it Green color
        Brembo brake package
        420 HP 5.0L
        Ford Racing Power Pack
          My car was on a Dyno Jet - Chassis Dyno as well going to the track soon just need to get re-tuned again after I put my Wideband in......been looking to get a vent pod....anyone have one or know where I can get the PVC pipe at.....nothing here in Canada
            there's a dual A-pillar gauge pod for sale in the For Sale section if you want to go that route
              I will make my own if I go that way...can get one at the junk yard for 50$ but trying to find one on ebay before I fork out 50$ on it.....Im a tool & Die Maker and been working with some carbon fiber latley and would be no problemto fab up. Plus I know a body manager at at dealership and would get painted to match the car when he's doing another siliver car...I like doing it right the first time but would perfer the vent pod would cost me like 20$ in PVC pipe vs 50$ plus the universal pod for 30ish$
                ^yeah I hear ya, I bought spare A-pillars locally from a guy parting out his GTO simply for that purpose. Fab up my own triple gauge pod on the A-pillar when I get bigger engine mods and need more gauges. To buy the triple from the only company that makes them costs I believe its $300 WITH sending in your own A-pillar but that includes laying stock cloth over everything so it looks factory but I think I can do it all on my own.
                I think I may have a custom cable made for my interceptors and order 3 more intercepters for the A-pillar. 5 intercepters would be so awesome
                  CRABS WAMS MPD GT-R Brembos and stuff
                    That was a DynoCom dyno not a Dyno Jet however it appears they ran it in the wrong gear (4th) judging by the torque numbers. You need to get it on Dynojet if you want to compare with other G6's and dyno it in fifth if you want an accurate representation of what its really making.
                    Chris White
                    http://www.GTOShiftLight.com
                    2006 Spice Red GTO - Stock
                    2012 Cherokee SRT8 - Stockish
                    • #25
                      You will never hit 5th gear it 1/4mile I just get out of third in it.
                      • #26
                        ..It doesn't matter. You run a Dyno in the gear closest to 1:1 or 1:1 if it has it.
                        3.6L's 6T70 has the following gear ratio
                        First: 4.48
                        Second: 2.87
                        Third: 1.84
                        Fourth: 1.41
                        Fifth: 1.00
                        Sixth: 0.74
                        Hence, 5th is what you run it in. They might have been confused as most 6-Speed cars (Usually stick..) 4th is 1:1 (Mine is in the GTO).
                        2005 CGM GTO.
                        • #27
                          ^huh, this I never actually knew.........learn new crap around this place all the time
                          • #28
                            I do feel that pontiac was more interested in crank hp instead of wheel in our case. It seems as though most have around 25% loss on dyno tunes. With those mods I think you should be putting out more but it seems that no matter what we add it doesn't help as much as it should. I've decided at this point to save money for my next ride prob a TB SS that will put down better number with less effort. But I have heard that our fuel injectors may be a sorce of our problem, as they can't give us the amount of fuel we need, although this theory hasnt been confirmed yet, that I know of, it does seem as though it could be a good possibility.
                            My Car Domain
                            Vector 93 ECM/TCM Dyno tune, Michelin Pilot Sport A/S Plus 235/50/18 , RacingLine Motor Mounts & Strut Bar, R1 Premium drilled rotors, Custom Exhaust w/ 4" tips, Inchannel Rain Guards, Crabs CAB & Front Pipe Upgrade, GXP rear bumper, 15% Ceramic Tint, Blue Calipers, Blue Dart Overlays, Upper Window & Lower Grill Chrome, Side GTP Emblems, Chrome Door Locks, 8k HID Head & Fogs, Pioneer Head Unit, Rockford Door Speakers
                            • #29
                              ^well throw in some different injectors and see if your tuner can pull any extra power out of the thing once its getting more fuel. If not then get your TBSS
                              • #30
                                Thats why I did the LSX mod. When I had the G6 GXP, I just didnt want to put a shitload of money into it with no increase in performance.
                                2009 Liquid Red G8GT
                                4 door mafia
                                93 octane VMS ecm/tcm tune
                                8000k hid's
                                Solo Mach Shorty & HFC's
                                Rotofab cai and radiator cover
                                13.207@107.11
                                330 hp/328 tq on a Mustang dyno
