the look really good. the only reason I will never do 20's is cause I cant afford the tires for them. I can barley afford the ones for the 18's on my car now.
I just looked at the site for them and I dont think they will fit. the added height of them and width. you will rub. 8.5" wide is pretty wide for our cars. and Im sure you will have a issue with clearance on the strut.
Depending on where you look the price of the tires isnt that much more expensive than those of 18s
I had 20 x 8.5 wheels with the 35mm offset on my G6 with 255x35r20 tires and had less rubbing than I currently have with the 235/50R18 that I am currently running on the stock 18" rims. I did not experience any problem with strut clearance and only minor wheel well rubbing. I love the 20" rim and would still be running mine except that my 20s clipped the brake caliper when I installed the Brembo brakes even with the 5mm spacer. I like your wheel selection and think that they will look great on your G6.
Good luck.
Thanks for the info, I won't be doing the 20's unless I can sell the 18's. So once and if the 18's sell then i'll look more into the 20's on my car.
2009 Ford Mustang Premium Pony 4.0L
2001 GMC Sierra SL 4.3L
