I am trying to figure out a way to run the fog lights as the DRLs instead of the low beams. I think I have it but wanted to run this by some of the knowledgeable people here before I start my car on fire and/or electrocute myself.
Basically I want to wire up a relay that switches on with the ignition and off when the headlamps are on. I want to retain normal foglight functionality as well. I came up with the following:
The reason why I chose to wire 85 and 86 to 30 on the DRL relay is because pin 30 on the DRL relay has power when the DRLs are off. When the DRLs are on, pin 30 on the DRL relay appears to be a ground. Would it be better to wire 85 and 86 to a headlight instead?
Is there any reason why this wouldn't work? Is there an easier way of doing what I'm trying to achieve?
