new member from ohio
  • new member from ohio
    hey everyone
    Just found this forum a few days ago searching for some information. Figured I would go ahead and register. Ive read alot of good stuff on here already.
    I own a 2006 Pontiac G6 GT 3.5L
    Just ordered an Ebay intake a couple days ago. Ordered the Chrome Intakes with K&N filter. sounded like a cool starting mod for me.
    I plan on removing the resonator, and looks like i may have to try to fabricate a cold air box. Unless anyone has any leads or ideas if those are obtainable.
    Other than that i did new brakes pads and rotors and new spark plugs.
    Re: new member from ohio
    Most people recommend getting the maintenance items out of the way if they haven't, then upgrade. There was only one full intake if I recall it was the CRAB intake. Otherwise, you'll need to make something yourself, but you should be able to find pictures of it and follow the same basic design.
    2007 Pontiac G6 3.5L V6 | 1998 BMW Z3 Dinan
      Thanks. I did my brakes, rotors, spark plugs, thermostat. Found out i never had a tcm batt fuse in. Shifting is much smoother now.
      Yeah ill see what i can come up with on the heat shield.
      Thanks for the reply.
