I also put in a BPi Velocity Stack - kinda too big, stretches the CRAB and the underside of the hood touches it, but I can open the dump cut out some more...
More Air! - No P0101 for you!!!!
I just wanted to show you all how wide the beam pattern is coming out of these Morimotos. If you were to see this in real life, you'd be amazed. Also, keep in mind my iPhone's camera can only capture so much of the beam pattern, meaning the beam pattern in real life is actually wider than what is shown.
This is on a 14' wall.
This is on the ceiling.
Tomorrow, I will post a picture comparing the output from this Morimoto to an Eagle Eyes projector. The difference is quite drastic.
....did you swallow a small child in you're grill?
No, a Murano. I left perfect imprints of the grilles on his bumper - we all braked so hard the guy behind me swerved to left on the shoulder and was next to me so it was side swipe him, the car to my right or the one in front. I'm pretty lucky that's all the damage that was done...
Damnit, that's a bummer. I was sick when that happened to me shortly after getting my 6.
Personally I'd go with the Duraflex GT Competition bumper cover. With the hammerhead, and lowered suspension, it would look killer!
Yuck, no. That bumper has too big of air vents. It's ultimately auquier's opinion though.
Today replaced with Power Slot Rotors, Hawk HPS pads and BMD SS brake lines
The rears were a bigger pain than I remember - I couldn't get the pads open wide enough to just slip onto the rotors, had to beat the caliper on with a rubber mallet - ugh...
