2007 GM 3.5L V6 VVT ( LZ4 )
    Re: 2007 GM 3.5L V6 VVT ( LZ4 )
    Alright I was directed to this... Not a 100% answer but my interpretation.
    If they really searched it out, they would see it. But their is no simple way to do it, so they will have to search pretty thoroughly into the cars pcm to see it.
    I think that we have G6s, we might get away with it.
    http://www.hptuners.com/forum/showthrea ... t=warranty
    2007 Dark Gray Metallic G6 Sedan 3.5L v6 A4
    Former cars... '85 Camaro, '94 Camaro, '00 Camaro, '92 Mustang GT
      The "newest" PCM I tuned was out of a truck, 2002 version so it had twice the flashable space. I used it . I don't think there were any "clocks" in it. Like something that says "this PCM has 3,000 hours on it but the BCM has 12,000 hours on it" or something similar. What is to prevent us from buying a second PCM for tuning and swapping in the original PCM for warranty work?
      wrath.com - just a bunch of nonsense in need of work
      2008 Pontiac G5 - Trailer Trash Mommy Mobile
      2007 Pontiac G6 V6 Sedan - Grandma Grocery Getter
      1999 NBS Chevrolet Silverado ECSB Z71 - Locked Grandpa Grocery Getter
      1987 Chevrolet longbox fleetside 2wd 1/2 ton - Or that's what the VIN says it is
      1984 Chevrolet K10 - ColoradoK5 "Rigs of CK5 2005 Calendar" November Rig
        and that my friends seems pretty brilliant.
        Question is... what kind of costs are we looking at with that?
        EDIT: $100-150 on the lower side if Malibu PCMs work, which I assume they would.
          Yeah, I'm not sure what year does what. I think 2007s would still have a pretty basic PCM, just different than the non-VVT cars. I'm not sure though. I used a 2002 PCM on my 99 Silverado because it was 10x better than the antique in my truck... but I needed a PCM designed for use with a throttle cable. I only paid $125 for my truck PCM.
            they had 3.5L G6s as well, just not as common as Malibu.
              Other than different tuning for E85 (LZE) does anyone know why GM has so many hp/tq ratings for the 3.5L V6 VVT motor depending on what car it's used in? Also, why has the hp/tq ratings changed between 2007, 2008, 2009?
              2007
              Applications: Horsepower: hp ( kw )
              Saturn Aura 224hp ( 167kW ) @ 5800 rpm SAE CERTIFIED
              Chevrolet Impala 211hp ( 157kW ) @ 5800 rpm SAE CERTIFIED
              Chevrolet Monte Carlo 211hp ( 157kW ) @ 5800 rpm SAE CERTIFIED
              Chevrolet Malibu 217hp ( 162kW ) @ 5800 rpm SAE CERTIFIED
              Chevrolet Malibu Maxx 217hp ( 162kW ) @ 5800 rpm SAE CERTIFIED
              Pontiac G6 ( coupe ) 224hp ( 167kW ) @ 5800 rpm SAE CERTIFIED
              Pontiac G6 ( sedan ) 224hp ( 167kW ) @ 5800 rpm SAE CERTIFIED
              Pontiac G6 ( convertible ) 217hp ( 162kW ) @ 5800 rpm SAE CERTIFIED
              Applications: Torque: lb-ft ( Nm )
              Saturn Aura 220lb-ft. ( 298Nm ) @ 4000 rpm SAE CERTIFIED
              Chevrolet Impala 214lb-ft. ( 290Nm ) @ 4000 rpm SAE CERTIFIED
              Chevrolet Monte Carlo 214lb-ft. ( 290Nm ) @ 4000 rpm SAE CERTIFIED
              Chevrolet Malibu 217lb-ft. ( 294Nm ) @ 4000 rpm SAE CERTIFIED
              Chevrolet Malibu Maxx 217lb-ft. ( 294Nm ) @ 4000 rpm SAE CERTIFIED
              Pontiac G6 ( coupe ) 220lb-ft. ( 298Nm ) @ 4000 rpm SAE CERTIFIED
              Pontiac G6 ( sedan ) 220lb-ft. ( 298Nm ) @ 4000 rpm SAE CERTIFIED
              Pontiac G6 ( convertible ) 217lb-ft. ( 294Nm ) @ 4000 rpm SAE CERTIFIED
              2008
              Saturn Aura 219hp ( 163kW ) @ 5900 rpm SAE CERTIFIED
              Saturn VUE 222hp ( 166kW ) @ 5900 rpm SAE CERTIFIED
              Chevrolet Malibu 219hp ( 163kW ) @ 5900 rpm SAE CERTIFIED
              Chevrolet Malibu Classic 219hp ( 163kW ) @ 5900 rpm SAE CERTIFIED
              Pontiac G6 ( coupe ) 219hp ( 163kW ) @ 5900 rpm SAE CERTIFIED
              Pontiac G6 ( sedan ) 219hp ( 163kW ) @ 5900 rpm SAE CERTIFIED
              Saturn Aura 219lb-ft. ( 297Nm ) @ 3200 rpm SAE CERTIFIED
              Saturn VUE 219lb-ft. ( 297Nm ) @ 3200 rpm SAE CERTIFIED
              Chevrolet Malibu 219lb-ft. ( 297Nm ) @ 3200 rpm SAE CERTIFIED
              Chevrolet Malibu Classic 219lb-ft. ( 297Nm ) @ 3200 rpm SAE CERTIFIED
              Pontiac G6 ( coupe ) 219lb-ft. ( 297Nm ) @ 3200 rpm SAE CERTIFIED
              Pontiac G6 ( sedan ) 219lb-ft. ( 297Nm ) @ 3200 rpm SAE CERTIFIED
              2009
              Applications: Horsepower: hp ( kW )
              Saturn VUE 222 hp ( 166 kW ) @ 5900 rpm SAE CERTIFIED
              Chevrolet Impala ( PZEV emissions ) 207 hp ( 154 kW ) @ 5800 rpm SAE CERTIFIED
              Chevrolet Impala ( Bin-5 emissions ) 211 hp ( 157 kW ) @ 5800 rpm SAE CERTIFIED
              Chevrolet Malibu ( PZEV emissions ) 219 hp ( 163 kW ) @ 5800 rpm SAE CERTIFIED
              Chevrolet Malibu ( Bin-5 emissions ) 221 hp ( 165 kW ) @ 5800 rpm SAE CERTIFIED
              Pontiac G6 ( PZEV emissions ) 219 hp ( 163 kW ) @ 5800 rpm SAE CERTIFIED
              Pontiac G6 ( Bin-5 emissions ) 221 hp ( 165 kW ) @ 5800 rpm SAE CERTIFIED
              Pontiac G6 RHT 217 hp ( 162 kW ) @ 5800 rpm SAE CERTIFIED
              Saturn VUE 219 lb-ft. ( 297 Nm ) @ 3200 rpm SAE CERTIFIED
              Chevrolet Impala ( PZEV emissions ) 215 lb-ft. ( 292 Nm ) @ 4000 rpm SAE CERTIFIED
              Chevrolet Impala ( Bin-5 emissions ) 214 lb-ft. ( 290 Nm ) @ 4000 rpm SAE CERTIFIED
              Chevrolet Malibu ( PZEV emissions ) 220 lb-ft. ( 298 Nm ) @ 4000 rpm SAE CERTIFIED
              Chevrolet Malibu ( Bin-5 emissions ) 221 lb-ft. ( 300 Nm ) @ 4000 rpm SAE CERTIFIED
              Pontiac G6 ( PZEV emissions ) 220 lb-ft. ( 298 Nm ) @ 4000 rpm SAE CERTIFIED
              Pontiac G6 ( Bin-5 emissions ) 221 lb-ft. ( 300 Nm ) @ 4000 rpm SAE CERTIFIED
              Pontiac G6 RHT 217 lb-ft. ( 294 Nm ) @ 4000 rpm SAE CERTIFIED
              http://media.gm.com/us/powertrain/en/pr ... G6_SAE.pdf
              http://media.gm.com/us/powertrain/en/pr ... nation.pdf
                2008 the way SAE rated horsepower changed, so the car power is actually the same just more accurate.
                2005 CGM GTO.
                  Any idea what exactly changed in the SAE dyno test that would make the hp/tq ratings different?
                    AWESOME! This is my car! SEARCH!
                    • #25
                      I thought in 2007 the engines became SAE certified. Then in 2008 they actually de-tuned the engine a bit to better match the transmission's torque handling capability.
                      • #26
                        Speaking of an earlier comment, I tried my buddy's 08 G5 stick twice and won both times. I get a car length at the start and none of us can get either pull ahead. From a roll if he gets a slight jump on me, he can pass me but it's close.
                        2006 "Silver Bullet" V6 Sedan
                        Mods = Lots HaHa
                        • #27
                          they added a cat too.
                          wrong.
