Dual Outlet Rear Lower Valance Part Number
This topic is closed.
  • Dual Outlet Rear Lower Valance Part Number
    Part Number 22712778
    This Item comes in a very big box, so if you're ordering it online, shipping may be costly.
    If you're picking it up at your local dealer with your G6, you will be removing it from the box in order to take it home.
    This part is fairly easy to install. There are small bolts along the sides, plastic push clips at the bottom, and tabs along the rear top. The use of a flat blade driver will come in handy in guiding the tabs away from the bumper.
