it is just pluging up the new shifter and letting the computer know that it is there...
Right Chris??
Well that depends on a few things
1. Is tapshift on these cars DIRECT IE wired to the TCM or is it sent via the bus from the BCM after the switch is closed?
2. Did I put the tapshift calibration in your ECM/TCM?
Chris White http://www.GTOShiftLight.com
2006 Spice Red GTO - Stock
2012 Cherokee SRT8 - Stockish
