Every once and a while my engine will shut off by itself (when its in gear) when im stopped. I've taken it into the dealership and they can't find the problem.
I had the same exact thing happen to me that you are describing for an 04 cavalier 2 months ago. It ended up being the ignition coil. The engine would studder when i was stopped and eventually die.
