http://www.ledunderbody.com/ Multi Color Install
  • http://www.ledunderbody.com/ Multi Color Install
    Ok ill start off by saying that I nor my father are NOT RESPONSIBLE for any screw ups, made by you or any other person by following instructions posted here.
    Ok now lets get down to business. You will need a Drill with a philips bit, needle nose plyers, and a regular philips screw driver.
    So I had a fuse splitter installed so it made it alot easier, if you need to know about how to install the fuse splitter talk to Chris.
    Now Pics Of the Product from ledunderbody.
    First Your going to want to strip the wires just a little to give you some room to work with.
    Black and red is the electrical wire....
    Plain black is the ground.
    Second u wana squeeze the red and black wire into the fuze splise as done here.
    Third there is a grounding plate, Use a 10mm Socket and unscrew the bolt. And attach the wire and screw back on.
    Run everything as normal where u want it. There is a little opening between the console to thread the leds and the controller. Here is the rest of the pics and a VID!!!
    Originally posted by Tupperware SC2
    I'm open to other ideas that'll make my car sick awesome super deluxe pro-friggin BOOYAH yo, as long as they're cheap.
    Re: http://www.ledunderbody.com/ Multi Color Install
    might want to edit your post and take out the profanity. good res. pics.
    750WHP Magnacharged GTO.....WTF!
    TVS2300 GTO, Innovators West 8" Overdrive Pulley, ECS Tensioner, SD tuned by Andrew at Complete street performance, Ed Curtis custom Lunati camshaft 230/236 .6XX/.6XX 113 LSA, Hardened Pushrods, Lunati .675 lift Valve Springs, Single Walbro 255 fuel pump in stock bucket, Kooks 1 7/8 Jet hot coated Headers , Kooks 3" catless mid pipes with DMH low pro electric cutouts, Spintech 2.5" stainless steel exhaust with X pipe, Carbon fiber Cold air box with AEM air filter, Billet products short shifter, JamesBiz Oil catch can, Pedders 5/16" raise springs with drag bags, Weld RTS Black with Hoosiers
    Show
    -20% tint
    -bohaman AUX-in radio mod
    -Professionally heated seats
      Edited and video embedded.
        ok cool.
        Show
        -20% tint
          1.) you listen to some real crap.
          2.) is there an option to set it to just stay on with one solid color?
          3.) can you set it to strobe one color to the music?
          4.) are they bright?...they dont look like they output too much light in the vid
          i just think the changing colors is too much....maybe in real life it would be diff.
            First of all, I can listen to w/e i want. The comment about what i listened was not needed. Onto your respectful questions.
            Yes you can select through options and modes of colors, and set it on one solid color, and dont know about the strobe for one color. I still have to tinker with it. And yes they are pretty bright. But not to bright to illuminate the car.
              Eh, the strobing's a little much for me, but it'd look pretty snazzy if you're just parked somewhere showing off. And that ain't too bad for metal, I can dig it (I drive my girlfriend nuts when I turn it to the local college radio station on chainsaw metal night , but I gotta be in the mood for it)
              Mods: Vector 93 ECM/TCM, Addco prototype 7/8" rear sway bar, Powerslot Cryo rotors, Hawk ceramic pads, Yokohama AVID W4S 245/45/18 on Cobalt SS/TC wheels, Pioneer DEH-P6900UB, Alpine PDX-1.600 pushing a 12" Kicker L7, Scosche DIC, Peripheral steering wheel control kit
                yea i dont listen to metal all the time. mostly when im pissed off ;D or in the mood for head bangin but i mostly listen to rap/hip-hop when im driving around.
