Re: **PLEASE READ BEFORE MODDING HEADLIGHTS**
the stress marks your referring to is called crazing it happens to heat molded acrylic (plexi) over time due to the elements (sun light salt sll the fun stuff!)but it can also be speed up by reheating or reforming theres no wat to really aviod it it happens! but then you take the acrylic off the rest of the light it relaxes and flexes also alot of headlights are "welded" together if you take it apart reweld them with a ips weldon 3 or 4 its a plastic chemical weld it fuses the plastics together and is your best way to seal them! i prob should have mentioned i run a plastic warehouse and do light fab work! also too a little tip dont ever clean your headlights with Windex or anything containing ammonia acrylic is porous and when ammonia is absorbed it turns yellow=foggy hazy lights hope this helps
