Homelink Overhead Consoles
    Re: Homelink Overhead Consoles
    Sent you payment info.
    For others, if you are not in the continental US, then shipping may incur an additional charge.
        Send me a lil info too.
          Bump. Still have these.
            bump. No one has followed through on these yet. Still available.
              I PM'd you.
                Hey sorry but could you message me back hah
                  I just responded to you via PM. I appreciate the enthusiasm, but it's only been a day since you messaged me.
                    Has my piece been shipped yet? I thought I would've received it this week.
                    • #25
                      Yours went out this weekend due to the weather and not being about to get to the post office. I sent it out priority though.
                      1 grey and 1 tan left.
                      • #26
                        Okay, thanks.
                        • #27
                          Now I'm pissed. The homemade harness was NOT plug and play!!!! The car has a 2-pin male plug and the harness has a 3-pin female plug! It doesn't fit WHATSOEVER!!!!!!!!!
                          • #28
                            I understand your frustration, as I was not expecting there to be an issue either. All of the cars I have looked at have had the 3 pin plug on the passenger side of the overhead console that connects to the dome lights.
                            First, I will offer you a full refund if this turns out not to be plug and play as I described. To help move forward, I have a couple questions for you regarding your car.
                            What year and model is it?
                            What does your current overhead console have on it? Lights, sunroof, speaker?
                            Do you have a picture of the connector you have, and maybe one of the inside of the overhead console?
                            At minimum, this will help me make sure this doesn't happen to someone else. At best, we'll get this resolved and find it will work with your car. If you would like, we can take this to PM to get it resolved.
                            • #29
                              For clarification, here is the bracket that the overhead console fits into. On the left of the image (which is the passenger side when in the car) you can see the connector where the wires are going to the connector. This is the connector you would use. You unplug it, and plug the wire harness I made into that.
                              • #30
                                I'll be honest with you, I didn't think to look over on the passenger side for a pigtail. I just assumed it was on the left because that's the only other pigtail besides the sunroof one that plugs somewhere on the trim piece itself. What you're saying makes sense because I don't know how I was expecting to draw power from the OnStar harness... Derp!
                                I apologize for the rather rude and unprofessional reply and I will update you tomorrow on what I find with the newly gathered information.
