4T45 Transaxle(MN5) (V6,GT)
This is a sticky topic.
  • 4T45 Transaxle(MN5) (V6,GT)
    Type: four speed front-wheel-drive, electronically
    controlled, automatic overdrive transaxle
    with electronically controlled torque converter
    clutch
    Engine range: 3.0L - 3.4L
    Maximum engine torque: 205 lb-ft (278 Nm)
    Maximum gearbox torque: 325 lb-ft (440 Nm)
    Gear ratios: First: 2.95 Second: 1.62 Third: 1.00 Fourth: 0.68 Reverse: 2.14
    Maximum shift speed: 5800 rpm
    Maximum validated gross vehicle weight: 1990 kg (4347 lb)
    Case material: die cast aluminum
    Shift pattern: (2) two-way on/off solenoids
    Shift quality: variable bleed solenoid
    Torque converter clutch: pulse width modulated solenoid control
    Converter size: 245mm (reference) (diameter of torque
    converter turbine)
    Fluid type: DEXRON VI
    Dry: 74.7 kg (164 lb)
    Wet: 85.1 kg (187.6 lb)
    Fluid capacity (approximate): bottom pan removal: 7L (7.4 qt)
    Complete overhaul: 10L (10.6 qt)
    dry: 12.5L (13.2 qt)
    Transfer design: two-axis design, link chain assembly
    2009 Panther Black G8 GT
    334 WHP 347 WTQ
    Nice Pic
    I saved it.
    06 Stealth Gray Metallic GT Coupe Dr Speed Stage III Thanks, WCC
      any way i can get my hands on a more detailed schematic of the tranny.
        maybe us GT owners can finally get something good for these!!
          Re: 4T45 Transaxle(MN5) (V6,GT)
          Delete me.
          334 WHP 347 WTQ
            Before you give me the I know...holy thread revival
            Anyway...can someone please confirm that the torque rating for the 4T45e is only 205 lb/ft
            If so, and please correct me if I'm wrong, it means that the trans was over powered from the factory as the LX9 has 222 lb/ft stock
            Progression Page - G6P Garage
            They had like 47 different kinds of diapers there so I picked up some ShamWow's and Duct Tape instead
              From the manual
              Maximum Engine Torque 4T45-E 215 lb ft
              According to Wikipedia the LX9 ranges from 213lb ft to 221lb ft. So I guess you are correct.
              2005 G6 V6, CRABS w/ Custom lower grill ram, Eibach on KYB GR-2, Racingline STB & Street MMI , R1 Concepts Slotted & Cross Drilled w/ Hawk Pads, GTP 18" Hyper White, DDM 3K Fogs.
                Paying someone to install parts on your car, and bragging about it being fast is like watching someone SMURF your wife, and being proud to raise the kids
                Progression Page
                Four Door Mafia
                Forever Pontiac
                Sponsored by: Negrotis™ Racing
                    Bumpage
                    Can anyone else confirm?
                      Yea.. GM site says this as well..
                        Enter: Sonnax
                        Sonnax offers cutting-edge transmission, torque converter and driveline products for the automotive aftermarket. Get hundreds of free tech resources online 24/7.
                        When I worked for Jasper Engines & Transmissions, these were the go-to guys for our Transmission division. The 45 is a little light on documentation, but the 65 has a bit more to peruse through!
                        GT-R Exhaust, 5000°K H.I.D., 15% Tint (All Around)
                        Loud Exhaust, Bright Lights, Dark Tint, Simple.
