well as you can see my car was not able to be dynoed the reason was that the shop that this dyno day was mainly works on imports like Subrus, Aucuas, Hondas, ect...., and he did not have the right tool to obtain my rev points and gears having it being fwd with a automatic trans. any way it was a great time and i did get some kinda a number. they did run it and without knowing any shift points etc... the WHP was 179 but he said that was going to be low for obvious reasons. also seeing that honda with 400+ WHP was amazing it was peeling out on the dyno outta 4th gear. here is the print out off all the cars that were there and there results
Dyno Day Results
This topic is closed.
Re: Dyno Day Results
that sucks man!
Show
-20% tint
-bohaman AUX-in radio mod
-Professionally heated seats
Show
-20% tint
179 is a relistic number, you have an 08 with 220 HP aprox and other G6s that have dynoed before have a near perfect 20% drop off. That puts you at a 44 HP drop off taking you to 176. So 179 is relistic2006 G6 GTP: Traded
2013 Mustang GT
Gotta have it Green color
Brembo brake package
420 HP 5.0L
Ford Racing Power Pack
Originally posted by dre256179 is a relistic number, you have an 08 with 220 HP aprox and other G6s that have dynoed before have a near perfect 20% drop off. That puts you at a 44 HP drop off taking you to 176. So 179 is relistic
ya but with the mods i have it should be higher then what stock ones have. also it was saying that i had 427 LBS of Torque wouldn't that be nice.
Originally posted by midnightG6GTya but with the mods i have it should be higher then what stock ones have. also it was saying that i had 427 LBS of Torque wouldn't that be nice.
Yea, I think it was off a little :P2006 G6 GTP: Traded
2013 Mustang GT
420 HP 5.0L
Originally posted by midnightG6GTOriginally posted by earlbaerThat Honda is impressive, but look at the torque.Black 2006 G6 GTP Leather and 3.9 liter
Originally posted by earlbaerOriginally posted by midnightG6GTOriginally posted by earlbaerThat Honda is impressive, but look at the torque.
ya im not sure what they meant by it but they said that he would probably be kicked off the track and the owner/dyno guy said that he would put his shop on the line that that is possibly one of the fastest honda in Michigan
