Results 1 to 8 of 8
Thread: 2008 GM 3.6-Liter VVT Engine With Direct Injection
  1. #1
    suckit
    G6 Beginner
    Jan 2008
    Lancaster, PA
    61
    Wow, I was reading in today's newspaper about the 08 CTS with the new 3.6L VVT. The newest 3.6L VVT has 304 HP and 370 ft-lb of torque! What an improvement from last year's 3.6L VVT. Looks like Cadillac only has this new 3.6L with direct injection techonlogy. I wonder if the new G8 will have this direct injected 3.6L VVT.
    significant horsepower and torque increases
    dramatic hydrocarbon reductions
    improved fuel economy
    GM Powertrain announced today it will deliver a 3.6-liter V-6 gasoline engine with direct injection and variable valve timing (VVT) technologies in the 2008 model year. A vehicle application will be announced later in the year.
    Additionally, it was forecast that by the end of 2008, GM will produce as many as 200,000 vehicles globally with direct injection technology, and by 2010, GM projects one out of every six GM vehicles in North America will be equipped with a direct injection engine.
    The application of direct injection technology to the 3.6-liter VVT engine – a member of GM Powertrain’s family of high-feature V-6 powerplants used on cars and trucks around the world – contributes greatly to a 15-percent increase in horsepower over the current levels that range from 240 to 267; an 8-percent increase in torque, and up to a 3-percent improvement in brake-specific fuel consumption (BSFC). An approximate 25-percent reduction in cold-start hydrocarbon emissions is also achieved.
    With direct injection, precisely metered fuel is delivered directly to the combustion chamber, which has a cooling effect in the chamber. Cooling the incoming air charge enables a higher compression ratio, which also improves engine efficiency. Less fuel is required to produce the equivalent horsepower of a conventional port injection combustion system.
    “The 3.6-liter VVT with direct injection will be our highest specific output non-turbocharged V-6 engine, as well as one of the most fuel-efficient offerings in our high-feature family,” said Tim Cyrus, chief engineer for high feature V-6 and Northstar V-8 engines. “It’s the latest example of our strategy to continue to reduce emissions and improve fuel economy without sacrificing performance.”
    This is GM’s third engine with gasoline direct injection. The announcement of the 3.6L VVT V-6 with direct injection comes on the heels of the introduction of GM Powertrain’s Ecotec 2.0-liter four-cylinder Turbo engine with direct injection on the 2007 Saturn Sky Red Line and Pontiac Solstice GXP roadsters. Also, since 2004, a naturally aspirated Ecotec 2.2-liter direct injection engine is equipped on Opel models in Europe.
    How direct injection works
    Direct injection differs from the fuel delivery process of a conventional engine by delivering fuel directly into the engine cylinder, where it is mixed with air. The combustion process of conventional fuel injected engines uses air and fuel that partially evaporates in the intake port or intake manifold prior to being introduced into the combustion chamber. Direct injection is a continuation of the evolutionary process of moving the fuel introduction point closer to the cylinder to improve control.
    With the 3.6-liter VVT with direct injection, fuel is introduced directly to the cylinder during the intake stroke. As the piston approaches top-dead center, the mixture is ignited by the spark plug.
    The fuel injectors are located beneath the intake ports. The intake ports only transfer air, unlike port fuel injection, which flows air and fuel, thus increasing efficiency. D irect injection also permits a slightly higher compression ratio than if the fuel were delivered with conventional fuel injection. The result is better fuel consumption at part and full throttle. The engine uses conventional spark plugs similar to other high-feature V6 engines.
    A high-pressure, returnless fuel system is employed. It features a high-strength stainless steel fuel line that feeds a variable-pressure fuel rail. Direct injection requires higher fuel pressure than conventional fuel injected engines and an engine-driven high-pressure fuel pump is used to supply up to 1,740 psi (120 bar) of pressure. The system regulates lower fuel pressure at idle – approximately 508 psi (35 bar) and higher pressure at wide-open throttle. The exhaust cam-driven high-pressure pump works in conjunction with a conventional fuel tank-mounted supply pump.
    Direct injection’s fuel delivery enables very efficient combustion to help reduce emissions, particularly on cold starts – the time when most tailpipe emissions are typically created. Also, direct injection permits a higher compression ratio – greater than 11.0:1 in the case of the 3.6 – which has a positive influence on fuel economy.
  2. #2
    suckit
    G6er Addict
    Feb 2006
    Toronto, ON
    3,447
    Name
    Calvin
    Year
    2006
    Make
    Pontiac
    Model
    Solstice
    Trim
    Base
    Engine
    2.4L I4 LE5
    Transmission
    5 Speed Manual
    Style
    Convertible
    Color
    Dark Steel Gray Metallic
    Re: 2008 GM 3.6-Liter VVT Engine With Direct Injection
    The 3.6L and 3.6L are still different engines, both available at the same time on the CTS. I think it's exclusive to Cadillac for the first year, then they'll start putting it in other applications.
    As for the G8, no it won't have it, at least now. Unless they start building them in Queensland. Holden doesn't source our engines here.
    <-- Gray G6? Click!
    2006 Solstice 2.4L I4 "Kristin", Shadow Gray Metallic, 1SA+JL9+G80
    +PCQ+ZQ2+ZQ3
    Life moves fast, don't miss a thing.
  3. #3
    Moderator suckit
    suckit
    G6 Post Whore
    dre256's Avatar
    Mar 2006
    Mount Laruel, NJ
    4,685
    Year
    2006
    Make
    Pontiac
    Model
    G6
    Trim
    GTP
    Engine
    3.9L V6 LZ9
    Transmission
    4 Speed Auto with Tapshift
    Style
    Coupe
    Color
    Electric Blue Metallic
    We talked about this a little while ago, it maybe possible to swap it over to the G6 but would require the PCM, heads, injectors, intake manifold upper and lower, wiring harness, ect.
    It possible to MAYBE see it in the future of the G6 when the parts are more readily avaible but due to engine bay restrictions it prob be more like 280-290 HP not the 304 seen in the CTS
    2006 G6 GTP: Traded
    2013 Mustang GT
    Gotta have it Green color
    Brembo brake package
    420 HP 5.0L
    Ford Racing Power Pack
  4. #4
    suckit
    G6er Addict
    Feb 2006
    Macomb Township, MI
    2,146
    I have one in my CTS and its amazing. Loud, but amazing Its not going in the G8 or G6 but it is however going in some other global platforms next MY. It's NOT swappable into a G6, way to many things wont work IE fuel system controller arch. ect I do know it WAS talked about for the G6 MCE but I believe it was nixed due to extra cost.
    Chris White
    http://www.GTOShiftLight.com
    2006 Spice Red GTO - Stock
    2012 Cherokee SRT8 - Stockish
  5. #5
    suckit
    Established G6er
    Aug 2006
    1,392
    umm it's 270 lb-ft not 370
    Appearance: Chrome Lower Grilles-Black Euro Tails-Red DupliColor Calipers-Red LED Dome/Map-Tint 15% All Around-4300K Fogs-8000K Lows-18" Black Konig Hotswaps-Pirelli PZero
    Performance: Stage 3/4 CAI-GTR Exhaust-VMS Tune
    Sound: 12" Kicker L7-Optima Redtop
    -Retrofit 2008 Radio Owner #3
  6. #6
    Why not Zoidberg? Photobucket
    suckit
    suckit
    suckit
    suckit
    G6er 4 Life!
    WoodburyMan's Avatar
    Jun 2007
    Woodbury, CT
    23,837
    Name
    Erik
    Year
    2015
    Make
    Chevrolet
    Model
    SS
    Trim
    Base
    Engine
    6.2L V8 LS3
    Transmission
    6 Speed Manual
    Style
    Sedan
    Color
    Perfect Blue Metallic
    XBox LIVE Gamercard
    WoodburyMan
    They had the plain 3.6L VVT in the CTS in the 2006 MY I think if memory serves me right, a year before the G6 got it. Who knows, maybe in the 2009-2011 Redesign we might get it or a variant of it.
    2005 CGM GTO.
  7. #7
    suckit
    G6er Addict
    Feb 2006
    Toronto, ON
    3,447
    Name
    Calvin
    Year
    2006
    Make
    Pontiac
    Model
    Solstice
    Trim
    Base
    Engine
    2.4L I4 LE5
    Transmission
    5 Speed Manual
    Style
    Convertible
    Color
    Quote Originally Posted by WoodburyMan
    Actually, the 3.6L first appeared on the 2004 CTS, as well as the 3.2L variant in the Alfa 159.
    <-- Gray G6? Click!
    +PCQ+ZQ2+ZQ3
  8. #8
    suckit
    G6 Beginner
    Jan 2008
    Lancaster, PA
    61
    Quote Originally Posted by Hello
    You're right, I just checked and the stupid newspaper article got it wrong, it's 370 Nm or 277 ftlb of torque. The newspaper had 370 ft-lbs
