HOW TO - remove the intake resonator in one piece way # 2
This is a sticky topic.
  • #76
    Re: HOW TO - remove the intake resonator in one piece way # 2
    Originally posted by ZoomThru View Post
    Had to replace the passenger wheel well and while I had it all out I decided to take off that intake resonator. Super easy to remove that way.
    Only difference I can tell is a subtle change to the sound.
    It was worth it though. I love how you can hear it better inside the car.
    • #77
      Might be worth it to shed the few pounds of plastic weight in the front. The change in the engine tone is there, but very subtle. Like you wouldn't know it unless I told you what I did.
      So I couldn't really suggest anyone do it just for the sound alone.
      Some were saying they felt better throttle response after the remove, but I got none of that.
      • #78
        Also, noticed alot of gravel and debris in the bottom tanks of the intake tube. Shaking the resonator around, you can hear alot of stuff trapped in there.
        This thing must help keep small rocks and stuff out of the airbox as well as water.
        Expecting my air filter will need changing more often.
        • #79
          just add a mesh screen over the hole. that should help eliminate almost all.
          • #80
            Very nice idea.
            • #81
              Very nice idea.
              Thanks. I'm full of them.
              • #82
                or just install the crabs and get the filter away from that hole lol
                • #83
                  Have kind of a plan consisting of getting a cheap ebay intake or something, and only upgrading the tube, and leaving the stock airbox. At least at first.
                  Pretty chrome intake tube connected to the black OEM airbox. No cone filter.
                  • #84
                    Originally posted by Ghost View Post
                    gee thanks ancr2001, its nice to still see people stealing my pics.
                    What exactly are you talking about? That's my pic bud. Check the link it's to MY photobucket. Like anyone wants to steal a pic of this! Get over yourself! If you are referring to the Pontiac pic then I say again, get over yourself. Didn't know you had special rights to Pontiac pictures on the internet.
                    2009.5 Pontiac G6 3.5 Base Premium Options
                    Modifications
                    Performance:
                    WAMS 93 Octane Tune, CRABS Intake (full kit + FPU), Racingline Motor Mount Inserts
                    Suspension:
                    Racingline Strut Tower Brace
                    Audio:
                    Kenwood Excelon DNN990HD Head Unit, Kenwood KFC-P709Ps Component System, Kenwood KAC-7204 Amp, 2 KFC-W3005 Subs, 1 KFC-XW1205DB Sub (not installed yet), Streetwires 14 gauge speaker cable, NVX RCA Cable, Big-3 Upgrade - 0 gauge & 4 gauge, 0 to 4 Gauge Scorpion Power & Ground Distribution Blocks
                    Interior:
                    Custom Gauge Lighting (in progress), Black Metallic Painted Gauge bezel, Blue LED Interior Accent Lights (underdash, backseat, air vents, dome, map)
                    Exterior:
                    LED Third Brake Light by AnderbrA Innovations
                    http://www.krylonix-server.com <--- My ride page
