If you hit the band button and it shows XM then you should be good. If it does show XM then you just have to go to channel 1 I believe to get the radio ID. The XM people will need that when you call to get the radio signal sent.
Current Mods: K&N Typhoon Air Intake System, 10000K DDM HID Lows and fogs, 6000K Highs, 18" Forte Nokturnal rims, Michelin Pilot HX MXM4 Tires, Chrome upper and lower grilles, self tinted tail lights, self painted interior pieces, RacingLine front strut tower bar, GT-R exhaust, Blue painted Calipers, Lampoon blue dart overlays, LED reverse lights, sometimes a WAMS tune,Brembo Brake Conversion, Cobalt SS rear Brake conversion, 15mm H&R Spacers, ATE Super Blue Racing Brake Fluid, Eagle Eye CCFL Headlights, Optima Yellow top Battery, Moog Control Arms & Tie rod ends, BMD SS Brake Lines, BMD Swaybar Links, White LED Gauge Lights,
Yeah I knew that, I have a g6 and I have that in mine but this is on my girlfriends g6 and it has the band button but didn't come with xm so I was wondering if I could get a xm receiver from a junked g6 and put it in wherever either the cable and connect the factory xm antenna already on the car, to the receiver and have it work like mine does
