Page 12 of 12 FirstFirst ... 2101112
Results 166 to 170 of 170
Thread: Cruisin's Drift RX-8; 3800 SC Swap
  1. #166
    suckit
    Established G6er
    CruisinG6's Avatar
    Join Date
    Nov 2009
    Location
    Northern Illinois
    Posts
    1,691
    Year
    2009
    Make
    Pontiac
    Model
    G6
    Trim
    Base
    Engine
    2.4L I4 LE5
    Transmission
    4 Speed Auto
    Style
    Sedan
    Color
    Carbon Black Metallic
    Re: Cruisin's Drift RX-8; 3800 SC Swap
    Quote Originally Posted by Altered6 View Post
    Doing some nice work there Cruisin.
    That could save you a bunch of aggravation down the road.
    Oh I'm trying ha
  2. #167
    suckit
    Established G6er
    CruisinG6's Avatar
    Join Date
    Nov 2009
    Location
    Northern Illinois
    Posts
    1,691
    Year
    2009
    Make
    Pontiac
    Model
    G6
    Trim
    Base
    Engine
    2.4L I4 LE5
    Transmission
    4 Speed Auto
    Style
    Sedan
    Color
    Buddy welded up the injector holes and took the extra step to smooth out the port from it.
    Went ahead with the cross member beneath the car to mount the trans and fab a ppf mount to hold the diff.
    Started with round tube and some steel plates to make inserts for the frame rails.
    Did the same for the other side
    also took some plated, drilled matching holes and welded on some nuts just to make assembly easier.
    Got some square tube and cut it to length with a bit of an angle to match the frame rail angle.
    Notched the square tube to fit around the brake/fuel lines and welded it up to the side plates. Bolts in place perfectly.
    Some 3/16 was added to cap off that notch so the tube was still closed off and strong.
  3. #168
    suckit
    Established G6er
    CruisinG6's Avatar
    Join Date
    Nov 2009
    Location
    Northern Illinois
    Posts
    1,691
    Year
    2009
    Make
    Pontiac
    Model
    G6
    Trim
    Base
    Engine
    2.4L I4 LE5
    Transmission
    4 Speed Auto
    Style
    Sedan
    Color
    Moved the trans out of the way and popped in the aluminum Isuzu driveshaft. It fits without rubbing the heat shield, ppf, or any other component. Things are working out as planned which is very nice.
    Now to get the driveshaft shortened, finish off the ppf and complete the trans and engine mounts.
  4. #169
    suckit
    Established G6er
    CruisinG6's Avatar
    Join Date
    Nov 2009
    Location
    Northern Illinois
    Posts
    1,691
    Year
    2009
    Make
    Pontiac
    Model
    G6
    Trim
    Base
    Engine
    2.4L I4 LE5
    Transmission
    4 Speed Auto
    Style
    Sedan
    Color
    Photobucket has randomly decided to charge $400 a year for third party hosting of images. As a result my pictures are blocked. I am working on a solution to keep this post going.
  5. #170
    suckit
    Medium-Rare G6er
    Join Date
    Sep 2014
    Location
    Québec, Canada
    Posts
    489
    Year
    2006
    Make
    Chevrolet
    Model
    Malibu Maxx
    Trim
    SS
    Engine
    3.9L V6 LZ9
    Transmission
    4 Speed Auto
    Style
    Hatch
    Color
    Black
    Yeah. Avatars as well... How about using "Dropbox"? Maybe it could works.
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
