Page 1 of 8 123 ... LastLast
Results 1 to 15 of 120
Thread: **Spyder Halo Projector Headlight Retrofit**
  1. #1
    Projection Is Everything Photobucket
    Photobucket
    suckit
    suckit
    Established G6er
    D0M1NIX's Avatar
    Oct 2011
    La Crosse, WI
    1,469
    Year
    2008
    Make
    Pontiac
    Model
    G6
    Trim
    GXP
    Engine
    3.6L V6 LY7
    Transmission
    6 Speed Auto with Tapshift
    Style
    Sedan
    Color
    Carbon Black Metallic
    XBox LIVE Gamercard
    OVERHE4TED
    Hey! I have another retrofit for you guys!
    I found a pair of like-new Spyders with some bad bulbs and a couple wiring issues for a steal of a price.
    Please visit my Eagle Eyes retrofit thread (http://www.g6performance.com/forum/s...ad.php?t=25014). There's some good stuff in there!
    FYI: I do NOT grant anyone permission to use my pictures at free will. Please ask me for permission first. If I grant you permission, please put a reference to this post by using its link shown in your browser's URL bar and implement the proper credits to me. Thank you!
    This post is open to discussion, but please don't start fights about personal opinions or anything senseless like that.
    If you have any questions or picture requests (while I still have this housing open), please feel free to reply to this post and let me know.
    Anyway, onto the almighty Spyders!
    First thing's first, gotta open them up! First thing you need to do is remove the weather strip on top of the housing.
    Weirdly enough, it's not like any other G6 headlight. There are screws holding the strip there.
    Right screw
    Left screw
    The screws are taken out.
    All you got to do is strip it off! It's attached by 3M adhesive or something.
    Next, the metal clips around the bottom and right side of the housing need to be taken off. These are the inside clips.
    These are the bottom clips.
    IMPORTANT: Make sure you take EVERY bulb out of the housing before you put it in the oven.
    Get your housing ready to go into the oven.
    Preheat your oven to 250F.
    Set your timer to 5 minutes.
    Once the oven is preheated, put the housing in for 5 minutes. When time is up, work the housing apart and you'll have this.
    You'll notice the two halves have a hard time separating. That's because the of the halo wires. Take the shrink tubing off of the wires.
    Then pull them through their respective rubber grommets.
    The housing is completely separated!
    There's for sure more to come. As always, feel free to ask questions and suggest ideas!
  2. #2
    Photobucket
    suckit
    suckit
    Established G6er
    D0M1NIX's Avatar
    Oct 2011
    La Crosse, WI
    1,469
    Year
    2008
    Make
    Pontiac
    Model
    G6
    Trim
    GXP
    Engine
    3.6L V6 LY7
    Transmission
    Style
    Sedan
    Color
    XBox LIVE Gamercard
    OVERHE4TED
    Re: **Spyder Projector Headlight Retrofit**
    Hey there! Just got some more pictures for you!
    The next thing I wanted to do was further disassemble the headlight. Here is a view of the back of the black-painted plastic piece.
    These are the halo wires.
    To take the black-painted plastic piece out of the lens, there are two screws that need to be taken out. Here is the one beneath the high beam slot.
    Here is the one beneath the blinker-ish sort of area.
    Screw out.
    Screw out.
    Wiggle it out and it's ready to go!
    To take both of the halos out, there are two screws on each that need to be taken out. Here are the halo screws behind the projector slot.
    Here are the halo screws behind the high beam slot.
    Here are the screws to take off the eyebrow.
    Low beam halo is out.
    No wonder why the LED halos in these things are dim! They are two SMD LED's! Shameful...
    Both halos are out.
    Eyebrow is out.
    It turns out the eyebrow is simply a long piece of plastic screwed in front of a strip of chrome. Pretty stupid if you ask me, but don't worry. I have an idea for improvement.
    More to come!
  3. #3
    Photobucket
    suckit
    suckit
    Established G6er
    D0M1NIX's Avatar
    Oct 2011
    La Crosse, WI
    1,469
    Year
    2008
    Make
    Pontiac
    Model
    G6
    Trim
    GXP
    Engine
    3.6L V6 LY7
    Transmission
    Style
    Sedan
    Color
    XBox LIVE Gamercard
    OVERHE4TED
    More pictures of disassembly!
    The next thing I needed to do was get the other half of the housing all stripped down. Here is the projector and high beam reflector.
    To take the projector and high beam reflector out of the housing, you need to disconnect both of their respective ground wires. This is the projector with its ground wire disconnected.
    This is the high beam reflector with its ground wire disconnected.
    Also, make sure to pull out the wires by the high beam slot along with its rubber grommet.
    The wiring is completely out of the housing.
    To take out the projector and high beam reflector, you need to completely unscrew them from their aiming adjusters. Here are the projector's aiming adjusters.
    An 8mm socket fits perfectly.
    After a bit of unscrewing, the projector is out.
    Here are the high beam reflector's aiming adjusters.
    An 8mm socket fits perfectly on these as well.
    After a bit of unscrewing, the high beam reflector is out.
    There she is all gutted out!
    I found why the projectors that come in these have terrible output. Pictures of that are to come.
  4. #4
    Photobucket
    suckit
    suckit
    Established G6er
    D0M1NIX's Avatar
    Oct 2011
    La Crosse, WI
    1,469
    Year
    2008
    Make
    Pontiac
    Model
    G6
    Trim
    GXP
    Engine
    3.6L V6 LY7
    Transmission
    Style
    Sedan
    Color
    XBox LIVE Gamercard
    OVERHE4TED
    Now here, ladies and gents, is why the projector that comes in these things have terrible output.
    Here is a view of the projector from top-down.
    Notice how close the halogen H1 bulb is to the cutoff shield. This is where length issues from HIDs come into play since they're a bit longer than halogen H1's.
    Another view
    Here is the output using that halogen H1 bulb on a 9V battery, so that's why it's more yellow and dim than usual; however, notice that section where there's no light?
    That's because the top of the reflector bowl is burned! Can anyone say cheap projector?!
    Well, I took off that metal thing that was screwed to the cutoff shield to see if that would do anything. I've never seen it on any other projector and I can't think of what the purpose of it would be.
    Here is the output with the same bulb and 9V battery with that metal piece out. It's already improved, but the spot that's vacant of light still remains due to the burned section of the reflector bowl. Also, that hole could easily be fixed with some JB Weld.
    The moral of the story is don't buy Spyders to use long term unless you plan to replace the projectors down the road. The projectors absolutely suck in them; they were poorly designed and were made of cheap materials.
  5. #5
    Photobucket
    suckit
    suckit
    Established G6er
    D0M1NIX's Avatar
    Oct 2011
    La Crosse, WI
    1,469
    Year
    2008
    Make
    Pontiac
    Model
    G6
    Trim
    GXP
    Engine
    3.6L V6 LY7
    Transmission
    Style
    Sedan
    Color
    XBox LIVE Gamercard
    OVERHE4TED
    Just bought these puppies for the side LEDs!
    http://www.ebay.com/itm/251343629682...84.m1439.l2648
    And these for the yellow sidemarkers!
    http://www.ebay.com/itm/230881436395...84.m1439.l2649
  6. #6
    Photobucket
    suckit
    suckit
    Established G6er
    D0M1NIX's Avatar
    Oct 2011
    La Crosse, WI
    1,469
    Year
    2008
    Make
    Pontiac
    Model
    G6
    Trim
    GXP
    Engine
    3.6L V6 LY7
    Transmission
    Style
    Sedan
    Color
    XBox LIVE Gamercard
    OVERHE4TED
    Just an update for you all. There hasn't been any progress with the projectors or HIDs yet because they've just been ordered, but I think the following stuff is worth mentioning.
    I felt obligated to replace the accessory LEDs on these things because most of them were burned out when I bought them. The LEDs I bought were a little too big for the slots.
    Another view
    Do you see where the flat part is in these slots?
    I had to dremel them out to make them fit.
    Woohoo, they fit!
    I tried a 5x5050 SMD LED bulb in there, but I didn't like it that much.
    Now, these Samsung LEDs are flipping bright!
    Here's a shot one in each slot.
    From farther away...
    To prep for the Morimotos, I had to take a few pieces of hardware out of the Spyder projectors: the ball joint (top left or right, depending on which projector is in question) and the adjusters (bottom).
    Ball joint
    Adjusters
    To take the ball joint out, you need to push in both of its tabs at the same time and push. They're sorta-kinda visible here. It's a pain in the butt to do this, but please take your time. You don't want to break it.
    To take the adjusters out, pinch the two legs together and push. This is extremely simple compared to getting the ball joint out.
    Of course, do the same with the other adjuster.
    They're out!
    At this point, I'm just waiting for the Morimotos to come in. It'll be another week or so before the DDM Tuning HIDs come in because I just ordered them today.
  7. #7
    Photobucket
    suckit
    suckit
    Established G6er
    D0M1NIX's Avatar
    Oct 2011
    La Crosse, WI
    1,469
    Year
    2008
    Make
    Pontiac
    Model
    G6
    Trim
    GXP
    Engine
    3.6L V6 LY7
    Transmission
    Style
    Sedan
    Color
    XBox LIVE Gamercard
    OVERHE4TED
    Here's a little something for ya.
    One of the little things that bothered me was the corner accessory bulb that came in these things, so I bought yellow 5x5050 SMD LED bulbs.
    I like it more than the old bulb that was in there.
    That wasn't much, but it was an improvement in my book. All the little things, all the little things...
  8. #8
    Photobucket
    suckit
    suckit
    Established G6er
    D0M1NIX's Avatar
    Oct 2011
    La Crosse, WI
    1,469
    Year
    2008
    Make
    Pontiac
    Model
    G6
    Trim
    GXP
    Engine
    3.6L V6 LY7
    Transmission
    Style
    Sedan
    Color
    XBox LIVE Gamercard
    OVERHE4TED
    The Spyder housings have shipped and will hopefully be here on Friday! Whoop whoop!
  9. #9
    Photobucket
    suckit
    suckit
    Established G6er
    D0M1NIX's Avatar
    Oct 2011
    La Crosse, WI
    1,469
    Year
    2008
    Make
    Pontiac
    Model
    G6
    Trim
    GXP
    Engine
    3.6L V6 LY7
    Transmission
    Style
    Sedan
    Color
    XBox LIVE Gamercard
    OVERHE4TED
    The housings have arrived and are in (mostly) good shape! I'll get this thread going tomorrow for you guys.
  10. #10
    suckit
    Medium-Rare G6er
    Jonah52's Avatar
    May 2013
    Cleveland, OH
    229
    Name
    Jonah
    Year
    2007
    Make
    Pontiac
    Model
    G6
    Trim
    GT
    Engine
    3.5Lvvt V6 LZ4
    Transmission
    4 Speed Auto
    Style
    Sedan
    Color
    Techno Gray Metallic
    XBox LIVE Gamercard
    Jonah52
    I feel like an insider lol
    Techno gray 07 G6 GT Sedan 20% tint, 6000K HID's, red LED floor lights, intake resonator removal, LED interior and reverse lights, debadged rear dart, gm emblem and pontiac emblem, and black emblem overlays.
    Build thread: http://www.g6performance.com/forum/s...ad.php?t=24478
  11. #11
    Photobucket
    suckit
    suckit
    Established G6er
    D0M1NIX's Avatar
    Oct 2011
    La Crosse, WI
    1,469
    Year
    2008
    Make
    Pontiac
    Model
    G6
    Trim
    GXP
    Engine
    3.6L V6 LY7
    Transmission
    Style
    Sedan
    Color
    XBox LIVE Gamercard
    OVERHE4TED
    Quote Originally Posted by Jonah52 View Post
    You were the first one to know.
  12. #12
    Photobucket
    suckit
    suckit
    Established G6er
    D0M1NIX's Avatar
    Oct 2011
    La Crosse, WI
    1,469
    Year
    2008
    Make
    Pontiac
    Model
    G6
    Trim
    GXP
    Engine
    3.6L V6 LY7
    Transmission
    Style
    Sedan
    Color
    XBox LIVE Gamercard
    OVERHE4TED
    OP updated
  13. #13
    Photobucket
    suckit
    suckit
    Established G6er
    D0M1NIX's Avatar
    Oct 2011
    La Crosse, WI
    1,469
    Year
    2008
    Make
    Pontiac
    Model
    G6
    Trim
    GXP
    Engine
    3.6L V6 LY7
    Transmission
    Style
    Sedan
    Color
    XBox LIVE Gamercard
    OVERHE4TED
    What do you guys think of converting the useless plastic eyebrow to a fiber optic LED bar similar to shown in the image below? I was thinking of a yellow or white LED fiber optic bar.
    http://www.dashzracing.com/images/P/2LHP-WRX08-TM.jpg
  14. #14
    Photobucket
    Photobucket
    suckit
    Medium-Rare G6er
    bjohnsong6's Avatar
    Dec 2013
    Florida
    477
    Name
    Bryant
    Year
    2006
    Make
    Pontiac
    Model
    G6
    Trim
    GT
    Engine
    3.5L V6 LX9
    Transmission
    4 Speed Auto with Tapshift
    Style
    Coupe
    Color
    Emerald Green Metallic
    XBox LIVE Gamercard
    seminolesrising
    Quote Originally Posted by D0M1NIX View Post
    I would do the fiber optic LED. It looks really sharp. Better than the eyebrow lol dang I really like that dashz led bar
    GONE BUT NEVER FORGOTTEN
    2006 G6 GT Coupe | Emerald Green | Plasti-dipped Emblems | Silverstar ZXE's | CRABs Opt. 3 + FPU | OBX Exhaust | Eibach Springs |
    Current Ride: 2004 BMW 330i ZHP | IMOLA RED | 6MT
  15. #15
    Photobucket
    suckit
    suckit
    Established G6er
    D0M1NIX's Avatar
    Oct 2011
    La Crosse, WI
    1,469
    Year
    2008
    Make
    Pontiac
    Model
    G6
    Trim
    GXP
    Engine
    3.6L V6 LY7
    Transmission
    Style
    Sedan
    Color
    XBox LIVE Gamercard
    OVERHE4TED
    Quote Originally Posted by bjohnsong6 View Post
    Do you think I should make the LED replaceable or one color?
