Results 1 to 5 of 5
Thread: SNUBBER. Engine Mount Dampening.
  1. #1
    Photobucket
    G6 Beginner
    Feb 2013
    69
    Year
    1964
    Make
    Pontiac
    Model
    G6
    Trim
    Base
    Engine
    2.0L I4 S/C LSJ
    Transmission
    4 Speed Auto
    Style
    Coupe
    Color
    Liquid Silver Metallic
    what are the symptoms when the SNUBBER. Engine Mount Dampening. goes out .. i have engine vibration and sometimes hard shifting..
    no check engine on ...... i found thid part online for 63 bucks... i belive it is original ... i got this car 7 months ago soo i am learning this car ....
    this vibration is driving me crazy ..
  2. #2
    Photobucket
    Medium-Rare G6er
    Apr 2013
    308
    Re: SNUBBER. Engine Mount Dampening.
    Nrg performance and spoon also sell performance torque dampers. Supposedly the short version will bolt right in. Nrg is carbon fiber look or something spoon is that sweet blue aluminum stuff can't remember off hand what its called. Still relativly new to my g6 I've come accross threads mentioning the same problem and suggestions to replace the damper. Don't recall anyone actually saying it took care of the problem.
  3. #3
    Photobucket
    G6 Beginner
    Feb 2013
    69
    Year
    1964
    Make
    Pontiac
    Model
    G6
    Trim
    Base
    Engine
    2.0L I4 S/C LSJ
    Transmission
    4 Speed Auto
    Style
    Coupe
    Color
    Quote Originally Posted by Drakon543 View Post
    yeah well i want to try the original from gm....anyways do you know any symptoms when those things fail
  4. #4
    Photobucket
    G6 Beginner
    Feb 2013
    69
    Year
    1964
    Make
    Pontiac
    Model
    G6
    Trim
    Base
    Engine
    2.0L I4 S/C LSJ
    Transmission
    4 Speed Auto
    Style
    Coupe
    Color
    Does any 1 knows the symptom when that peace goes out,... and how to inspected?
  5. #5
    VIP Member
    Photobucket
    Photobucket
    Photobucket
    Photobucket
    G6er Addict
    cmessick's Avatar
    May 2009
    Lafayette, Indiana
    2,786
    Name
    Cade
    Year
    2005
    Make
    Pontiac
    Model
    G6
    Trim
    GT
    Engine
    3.5L V6 LX9
    Transmission
    4 Speed Auto with Tapshift
    Style
    Sedan
    Color
    XBox LIVE Gamercard
    SilveRedGT
    i want to say your motor will experience more vibration. I have noticed without mine attached, I get some heavier vibrations at a certain RPM that is transmitted thru my steering wheel.
