brakes on 06 g6.. will these work/
Re: brakes on 06 g6.. will these work/
I really like thoseBlack 2006 G6 GTP Sedan 6M
Mods- 18" Forte F57 Phantoms with Kumho Ecsta 4X 235/45-18 from Discount Tire, Unique Coatings Tinted Tails, Racinline front strut bar and motor mount inserts, CRAB CAB, WAMS 93 octane tune, BMD Adjustable Swaybar Endlinks, Black Overlays, 5% tint, Spyder Smoked/Chrome Projector Headlights with 6k HID's, Complete LED Conversion Inside and Outside, Bluetooth
It says they fit. I don't see why they wouldn't. Contact them and ask. All G6 brakes are the same I thinkLast edited by MaYkO; 05-13-2013, 12:51 PM.Black 2006 G6 GTP Sedan 6M
all G6 brakes are the same
Originally posted by bobmundo123 View Postso just to clarify... we're good to go on these.. lolBlack 2006 G6 GTP Sedan 6M
Originally posted by bobmundo123 View PostCurrent Mods
245/45/17 Bridgestone Potenza RE-01 R, 245/45/17 Bridgestone Blizzak WS60, Eibach springs, Debadged, Recessed upper grills, GTP rear valance, GXP exhaust, Redline Tuning QuickLifts, K&N air filter, GMPP strut tower brace, Steering wheel stereo controls, Baer Cobalt 13" front brakes, Cobalt SS 11.75" rear brakes, Stainless steel braided brake lines front & rear, Leather steering wheel, Recessed lower grills, Leather shifter handle, Leather parking brake handle, Leather console lid cover, Volant intake, PIAA H9 & H11 Xtreme White Plus headlights & driving lights, 93 octane tuned ECM & TCM, Custom painted headlights, Motorsport Tech wheel adapters, C5 Corvette 17" x 8.5" wheels, Koni Sport struts and shocks, MSD 8.5mm Super Conductor plug wires, Racingline polyurethane motor mount inserts...
Altered6 Progression Page
Originally posted by Altered6 View PostSome G6 models had 276mm diameter front rotors as opposed to the typical 296mm. IIRC the smaller front rotors had to do with non ABS models. Maybe contact the seller prior to purchase and see what their input is. Nice find by the way.
just remember you get what you pay for. $200 for all 4 rotors is pretty cheap. which means they are thin made with cheaper steal and will probably warp faster. also the black will come off as soon as you apply the brakes (where the brake pad makes contact with the rotor)
Originally posted by ahuhnso i just realized there a drawer in my room that has nothing in it but tequila, condoms and a blow up doll. cant figure out if thats a good thing or not
Yeah...these are the exact same rotors as the Callahan ones and all the other ones on eBay. They're all made the same. Even the EBC Ultimaxx Sport versions I got suck and are already warping after a year.
After having the best rotors out there, I'm going back to OEM. I figure more material, less chance of rotors warping.
Save up for a BREMBO upgrade if you can.
